PDA
View Full Version : Big Blocks
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. lack of oil at top end
  2. Accelerator pedal that periodically "sticks"
  3. 54 88 324
  4. Cylinder head castings?
  5. DCM- Thermal Vacuum Switch replacement
  6. Educated guess?🤔
  7. Exhaust manifold gaskets on a 455
  8. Hi I’m new here looking for anyone with similar engine build
  9. To trim or not? 460 ford rear main seal
  10. Identify this 69 Olds motor (help)
  11. 64 Olds 394 Crankshaft removal
  12. 455 crank and rods
  13. Carburetor and intake manifold selection
  14. Oil leak - head gaskets?
  15. 442 .921 lifter HELP
  16. 455 running hot
  17. 1968 Olds 98 dieseling issue
  18. Deck Height, squish and quench
  19. 72 cs u code 455 motor
  20. Whether to add inline fuel filter to 67 400ci?
  21. Height of 455
  22. Thornton W Z manifolds
  23. Valve springs
  24. 1970 W30 Distributor Cam
  25. 69 455
  26. 1972 455 engine block markings.
  27. What is the D1 on this water pump mean?
  28. HELP! Scratch in head gasket mating surface: bad or not a big deal?
  29. mild cam--detonation
  30. Aluminum intake ID
  31. G vs. GA heads
  32. Block and head ID
  33. What does this tell me?🤔🤔🤔
  34. 455 street build
  35. 455 Rebuild--Sat for 3 years
  36. Newbie tear down and rebuild 455 olds
  37. ‘65 J88 engine question(s)
  38. What's the difference?🤔🤔🤔
  39. L9E0? Warranty engine?
  40. Questions about head bolts and gaskets
  41. engine gasket
  42. Qjet bolts needed
  43. Eagle Rotating Assembly - Balanced
  44. 1970 455 Help! Hone or Bore?
  45. Quadrajet Rods and jets suggestions.
  46. New guy to fourm from Iowa
  47. Can you help provide guidance for Lambda tuning?
  48. Basic: 455’s: PCV on which cylinder bank?
  49. Pertronix Flame Thrower III and OEM Tach
  50. help with CR math 455 build
  51. Looking for
  52. Stumble above about 4300
  53. Spark Plug Reading
  54. Holley Sniper 4150 EFI Installation - Lessons Learned and Experiences
  55. 455 id
  56. 394 Alternator mounting bracket (61 88) for Alt conversion
  57. Fi Tech !
  58. 455 rust in bore
  59. Vacuum Pump for Olds 455 Rocket
  60. 455 swap into 77 442
  61. 68 455 in 72 cutlass convertible help
  62. Holley carb duel feed line
  63. Exhaust manifold replacement....
  64. Overheating
  65. 69 Olds 442 - Need to get Engine turning - HELP Please!
  66. Headers Advice
  67. 455 dyno ?
  68. 1973-1974 442 455 dual exhaust system needed.
  69. Help needed please 73 455
  70. Fitech / 455 / Pertronics III / hotter cam / Pro Comp alum.heads / Help needed
  71. 455 Olds W25 question
  72. 68 Olds 455 R43S
  73. 62' Starfire engine id
  74. Holley Sniper / Hyperspark EFI installed...
  75. Clip for RamAir Actuator?
  76. Shopping for a 455 in AZ
  77. '66 425 D block, B heads
  78. Spreadbore Holley
  79. Icon or Keith Black
  80. 71 455 Fitech EFI and Offenhauser
  81. 1965 425 A heads motor
  82. 455 engine vin number
  83. Exhaust 455
  84. engine swap 403
  85. Ever wonder what a 20K mile 50 year old motor looks like inside?
  86. thrust bearing and crank destroyed
  87. New build Engine runs like crap
  88. Exhaust Recommendations
  89. Too much vacuum advance causes high idling.
  90. 62' Starfire 394 water pump replacement
  91. QJ accelerator pump trouble
  92. Engine ID
  93. Compression ratio
  94. 455 Build Produces Little Power - Advice Requested
  95. Low Fuel Pressure
  96. 394 Knocking
  97. 455 4 speed Carb ID date
  98. 403 Power Steering Pump Rear Mounting Bracket
  99. Need lots of help, can’t get this 400 right...
  100. Big Block 455 engine noise-Clicking
  101. Engine not fired in 10 years
  102. 455 vs 495 low end torque
  103. Exhaust Issue ?
  104. Holley Sniper Quadrajet Global File and Settings?
  105. PCV Valve
  106. Olds Rocket Parts
  107. Help Needed with awful sound from my 42
  108. 1969, 442
  109. 1967 425 Harmonic Balancer
  110. Camshaft suggestions
  111. Noisy lifter fresh engine build
  112. Pulleys Help
  113. Original cam timing gear orientation
  114. Engine ID
  115. 455 loose rocker arm, with lots of sloppy lash.
  116. 69 442 400 awakens from 22 year hibernation (seeking advice)
  117. help! Needed 62 394 4 barrel intake manifold and more
  118. 1972 455 - Ga vs G heads
  119. 425 rocker problems
  120. Block id
  121. LiquiMoly 10W-60
  122. How far to go with a top end refresh?
  123. 455 v notch piston
  124. Header bolts or studs
  125. Random unmarked 455 intake
  126. Mid 60's B&C Body Aluminum Radiator option(s)?
  127. 394 Water Neck Spacer
  128. Parts source recommendation for 394 engine rebuild
  129. 1970 Radiator Clutch Fan vs Modern Electric Fans
  130. Recommendations for a BBO build
  131. Starter Heat Soak
  132. newbie timing question
  133. 68 Delmont 88 (455 in) - Hose that connects from thermostat to water pump
  134. Looking for timing advance curve recommendations
  135. reviving a 73 455, cooling system
  136. Value of c and g heads
  137. MSD distributor timing question
  138. 425 fuel problem ??
  139. 1971 w30
  140. 70' 455 rocket to overhaul or to build.
  141. Distributor Gear Orientation
  142. Poor Running built 455 with fresh Ka‘s
  143. Fwd 425
  144. Engine stall when idling for 15 min
  145. motorhome head and cam advice
  146. 1968 455 rocket vacuum diagram
  147. Cam
  148. Is this the airtex 40736?
  149. Motor mount help
  150. W30 valve springs
  151. Water outlet question 68 442.
  152. 425 pushrods
  153. Fuel filter 425 Toronado
  154. Radiator replacement reccomendations
  155. 425 Head Gaskets Not Sealing...
  156. Good better nest H2O movers
  157. heat cross over plugs
  158. 1967 400 gasket set
  159. Can I get a picture?
  160. 455 main bearings
  161. 1961 394 mechanical pump mount location
  162. 455 cam bearing question
  163. 394 Radiator bleed hose
  164. Olds 455 Odd sound
  165. Belt help
  166. fuel system
  167. Throttle cable
  168. Cam recommendation
  169. 394 Water Pump bolt question
  170. Engine noise
  171. 72 cutlass 455 valve cover bolt sequence?
  172. Spark plug gap 72 Olds Stroked 455
  173. 1969 455 engine color
  174. nitrided distributor gear
  175. Looking for Mechanical Fuel Pump Recommendation
  176. Suggestions on parts.
  177. stock rockers !!
  178. 455 W30 Intake Manifold
  179. Lifter or Header?
  180. Which carb and intake? HP Torque estimate? HEI recurve kit. Street/Strip 455
  181. Where does it go ?!
  182. big block "C" heads cutting 0.010" how many CCs?
  183. 58 Olds carby swap
  184. 58 Olds 371 carby
  185. Flex plate orientation and rocker arm, pushrod orientation on a ‘71 455
  186. 64/394 lifter preload and headbolts
  187. Sealant for Factory Shim?
  188. Correct Way to Paint the 455??
  189. jm-25-28 cam work in this set up
  190. Pulley help
  191. Steel fuel line question
  192. Would You use these piston rings? Quick Seater Brand
  193. ARP Rocker Stud Torque Spec (3/8" stud/5/16" bottom thread)
  194. 1966-67 400 E block
  195. Need olds engine builder in nor CA
  196. Aluminum heads | Mech Fuel pump hitting head
  197. Best deadhead mechanical Olds fuel pump
  198. '69 4-4-2 won't start
  199. engine builder
  200. Olds Toro pan 5 qt
  201. Windage tray studs
  202. Question about the 1972 L75 455...
  203. Breather/PCV Setup
  204. Building an old Marine 455 for my '79 C10 Pickup
  205. Valve Spring Seat Depth
  206. 1970 Cutlass 455 with Performer/Quadrajet OAI Air Cleaner clearance?
  207. 68 BO7 Apprender 455 390hp carb and distributor question
  208. 1966 425
  209. Variation on engine vin derivative stamping
  210. Removing 72 455 exhaust studs
  211. 400 CID how much Oil?
  212. Oil Pressure Sender broke off in the block (Brass)
  213. Looking for cam recommendations for a 425 olds...
  214. 455 olds roller rockers
  215. Moroso oil pan pickup issue
  216. Comp cams kit,1442
  217. 67 400 Ponder This...
  218. 1966 Oldsmobile Delta 88 Carburetor, Intake Manifold and Dual Exhaust
  219. What's the beat intake manifold
  220. Intake from "The Parts Place"
  221. Excessive crankcase pressure
  222. Overheating 1971 455
  223. 1965 425 A-Heads Rocker Arm Pivots
  224. Drilling crank for pilot bushing
  225. assesorys brackets bb vrs sb
  226. Oil on top of Pistons after rebuild
  227. Need converter advice
  228. Engine accessory brackets pics/drawings 1970 455
  229. Need power steering pump bracket
  230. 455 with dorman balancer
  231. Effective stud length
  232. 72 Olds Cutlass 455 oil filler cap question
  233. 1970 OLDS 442 W-30 variable power loss..
  234. Need some Help with Brackets and Pulleys
  235. Milled pads c heads
  236. Starting specs
  237. Pump Gas 455 Build
  238. Best oil to use 425
  239. Metallic blue BBO engine paint 1970 and later
  240. Rebuild oil pressure question
  241. ready to drop it in
  242. Engine start after sitting
  243. quadrajet stock jet sizes
  244. Idle Adjustments for Winter & Summer
  245. Idle issue on my 455
  246. No oil to cylinder 4, 6 & 8 rocker
  247. Help
  248. Bad seals...can I still go?
  249. Where to get pushrods, rockers and bridges. 66-67 Toro 425
  250. Overflow Issue
