Block id
Old Jul 12, 2020 | 08:15 PM
Oldsvette's Avatar
Block id
Block id
I dont no how to id this number
Old Jul 12, 2020 | 08:54 PM
That is not a factory GM marking so there is no way to identify it.
Old Jul 12, 2020 | 09:16 PM
hurst68olds's Avatar
that is a factory making - or there wouldn't be so many of them - but it is for a service and/or industrial engine
Old Jul 13, 2020 | 07:07 AM
edzolz's Avatar
Show us the casting number above the water pump.
Old Jul 13, 2020 | 10:10 AM
Yes, you are correct. I should have said that is not a factory GM marking for a passenger vehicle application.
Old Jul 16, 2020 | 11:03 AM
rocketscientis's Avatar
#s on vin pad
Octavia would use last digit of year & # from 1-365 as code to keep track of things ....seriously doubt thats an engine we rebilt but # system was not exclysive...
looks to be a drill spot there also..assuming BB ,... does the web between timing cover and intake at the top of the block have a drill spot at 45 degrees from the driver side also
numbers are not right side up and all in a nice row which by no means indicates it was not put there by at th plant , they are just not vin# & none there is clue but not proof that it was not in a car
adis
Sep 28, 2020 08:42 AM
george landis
Sep 19, 2016 08:27 PM
olds_freak
Apr 29, 2015 08:23 PM
madmax442
Apr 2, 2014 05:29 AM
Tvan
Feb 14, 2012 10:48 AM
