Cam recommendation
Old May 26, 2020 | 02:51 PM
Spartan676971's Avatar
Cam recommendation
Hello Oldsmobile fans , I'm building a 455 and need some assistance with picking a roller cam. My car weight is 3600lbs , tire size 28 inches, massaged factory C heads , Edelbrock performer intake , headers , 2800 stall speed Auto , 3.42 rear . It's a street car . I called one manufacturer , I wanted another opinion to avoid regrets after the install . Thanks in advance
Old May 26, 2020 | 04:51 PM
cutlassefi's Avatar
Compression? Headers? Carb? Desired power and drivability?
Old May 26, 2020 | 05:17 PM
Yes , as stated , headers (long tube ) compression 10:1 , Holley 750-850 , eagle rotating assembly, 400+hp, light to light shenanigans .
Old May 27, 2020 | 09:46 AM
dragline's Avatar
Mike Jones will give you the best power with less valve train stress than anyone. Cost a little more but the quality is outstanding. Make sure to put ROLLER in the cam type block. I also recommend his valve train components
http://jonescams.com/street-performance/
yankees
Jul 18, 2013 08:30 AM
marlar98
May 6, 2013 03:12 PM
Velacyn
Mar 7, 2013 03:10 PM
Surftrip00
Sep 23, 2011 04:51 PM
alek72us
Nov 6, 2010 07:43 PM
