Looking for Mechanical Fuel Pump Recommendation
Old May 17, 2020 | 12:53 PM
Tjohn8573's Avatar
Looking for recommendations for a mechanical fuel pump for a mildly built 455. Headers, 830cfm Quick fuel Carb, performer intake, and cam.
Old May 17, 2020 | 12:55 PM
VinMichael's Avatar
Average parts store replacement should suffice. More important to have a regulator and gauge, so you actually know what PSI the pump is sending to the carb.
Old May 17, 2020 | 01:49 PM
Run to Rund's Avatar
I recommend RobbMc. In my case, the Holley chrome mechanical pump ran the engine out of fuel at about the 1/8 mile marker. That was with Tri-Carbs so any carb with smaller bowls would be impacted even sooner with that or other standard-volume mechanical pumps
Old May 17, 2020 | 03:31 PM
72455's Avatar
1972 U code Supreme
When I replaced the fuel pump in my '72 code Supreme I went with the AC Delco 41567. I'm running a Holley 770 Street Avenger, .030 bore and a W30 cam and it does well for me.
Old May 17, 2020 | 07:00 PM
Originally Posted by Run to Rund
I recommend RobbMc. In my case, the Holley chrome mechanical pump ran the engine out of fuel at about the 1/8 mile marker. That was with Tri-Carbs so any csarb with smaller bowls would be impacted even sooner with that or other standard-volume mechanical pumps
Good Lord those Holley pumps are junk! I think all my Olds buddies had them at one time or another, every one of them cracked or leaked fuel (both internally and externally!). Other than looking pretty (I guess if you like chrome) just about any other mechanical pump worked better
Old May 17, 2020 | 09:18 PM
Here's a picture of mine. All was well for many years until I installed a new camshaft and started spinning the engine to 5500 RPM, then all of a sudden I had fuel delivery issues. Did an optical inspection and voila, the classic crack through the pump body. An internet search revealed this was a very common issue.
Old May 18, 2020 | 06:33 AM
Rallye469's Avatar
Even the smallest McRobb is a great until. It pushed my car to 11.00 with no starvation anywhere on the track.
Switched to a full aeromotive set up and gained nothing.
Good luck!
-peter
Old May 18, 2020 | 06:47 PM
Tjohn8573's Avatar
Good luck!
-peter
Thanks for the replies. I definitely will not be getting the Holley.
archeryshooter
Sep 26, 2014 11:39 AM
67442nut
May 11, 2014 09:19 PM
Stevec
Aug 23, 2013 04:28 AM
67442nut
Sep 18, 2012 01:06 PM
geckonz08
Aug 12, 2008 08:49 PM
