62' Starfire 394 water pump replacement
Old Aug 26, 2020 | 10:38 AM
Wyoming Starfire's Avatar
Wyoming Starfire
I have a 1962 Starfire with a 394 in it equipped with air conditioning. I'm looking at replacing the water pump. (It's going out) is there a good aftermarket water pump I can use on this?
Old Aug 26, 2020 | 10:48 AM
rocketraider's Avatar
Oldsdruid
DK of a currently available new aftermarket but all 1949-62 Oldsmobiles use the same pump with variations for a/c and non-air.
Old Aug 26, 2020 | 10:50 AM
Wyoming Starfire
Could you recommend a good place to buy a replacement?
Old Aug 26, 2020 | 12:12 PM
I don't know that replacements are readily available. Craig at Mobileparts might have a lead on an NORS pump. Your only other option is to have yours rebuilt. Some vendors will do this on an exchange basis to reduce turnaround time.
Old Aug 27, 2020 | 05:39 AM
coldwar's Avatar
Search for Cardone 58-288 online. Classicoldsmobile site sponsor CarID has stock on them. Summit currently has a small stock on a exchange basis. Fusick also may have stock or the reproductions, call them.
Cardone is the last large rebuilder of these pumps for our cars. For a time they were NLA, glad they are once again rebuilding them.
https://www.carid.com/cardone/remanu...pn-58-288.html
https://www.summitracing.com/parts/a...ake/oldsmobile
Old Aug 27, 2020 | 07:03 AM
Good info, thanks for the update.
Old Aug 27, 2020 | 09:02 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I just looked and there are several on ebay. Most are for non A/C equipped cars but there are a couple for A/C cars. The A/C pump has eight blades on the impeller while the other pump only has 6 blades. It seems like the A/C pump has a ball bearing while the other has a sleeve but I am not 100% sure on that.
edzolz
Aug 6, 2020 09:13 AM
matt506
Jun 18, 2020 06:05 PM
spaceman_spiff
Aug 7, 2017 08:13 PM
J-(Chicago)
Mar 30, 2013 02:54 PM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
