Pertronix Flame Thrower III and OEM Tach
Old Oct 3, 2020 | 03:01 PM
Tjohn8573's Avatar
I just purchased a Pertronix III billet distributor you install in my 68 and new 455 build. I mainly ended up going with this distributor for the stock look and the rev limiter function.
The concern and question I have is that the instructions state that it is NOT COMPATIBLE WITH CURRENT SENSING TACHOMETER. Is the OEM rally pac a “current sensing” tachometer?
Old Oct 3, 2020 | 04:56 PM
PatL's Avatar
I believe your rally pac tach gets its signal from your coil. I always thought the inductive tachometers are current sensing (like a timing light). Wondering if they consider the pulse signal from the coil "current sensing"?
Old Oct 4, 2020 | 06:26 AM
Tjohn8573's Avatar
Is anyone running the Pertronix III with the stock tach that can answer this question? Thanks!
Old Oct 4, 2020 | 06:44 AM
The tach gets its signal at the coil- terminal from the Pertronix unit. Its the same signal that triggers the coil. The issue with the Pertronix III is that it provides a multiple spark that may or may not cause issues with your tach. The only way to know is to try it.
Old Oct 4, 2020 | 01:45 PM
My442's Avatar
Running a Pertronix III with an original Rally Pack.
No issues.
Old Oct 4, 2020 | 02:31 PM
Tjohn8573's Avatar
No issues.
Thanks for the replays all.
McIntosh
May 1, 2020 02:03 PM
ctreutel
Apr 18, 2014 02:02 PM
69ishHoliday
Oct 29, 2013 04:15 AM
jjokrm
Feb 21, 2013 08:51 PM
bobfo1
Nov 5, 2011 02:21 PM
