OEM Tachometer
Old Nov 5, 2011 | 01:35 PM
bobfo1's Avatar
OEM Tachometer
If you change to an HEI distributor (66 442) can you use the OEM tach with no issues?
Old Nov 5, 2011 | 02:21 PM
Yes. Just remove the tach wire from the original coil and connect it to the TACH terminal on the HEI distributor cap. You'll need to replace the terminal on the wire with a female spade terminal that fits the cap.
70cutlasssupreme
Jan 24, 2022 02:30 PM
alexrains
Dec 9, 2009 02:49 AM
guido
Dec 6, 2009 07:49 AM
wazoo
Hurst/Olds
Aug 27, 2009 01:36 PM
Florent.turbo
Sep 10, 2008 01:10 PM
