What's the beat intake manifold
Old Apr 8, 2020 | 08:05 PM
Gene kerr's Avatar
Looking for the best intake to use on my motor weekend cruiser slash street and strip these are my specs so far
455 .030 over je pistons 10.5 to 1
stock crank balanced
eagle rods
C heads bowl ported 2.125 valves
Hydraulic roller 110 / 569-572 /230-236
2800 to 3000 stall
Th400
1 7/8 headers
1969 cutlass with drag radials
Old Apr 8, 2020 | 08:23 PM
Battenrunner's Avatar
I will go first here......
Looks like a good combo with some nice potential, and a match for a Performer RPM air Gap #7551 if you have hood clearance, otherwise, a Performer #2551 will give you roughly .5 inch more hood clearance but may give up a little HP compared to the RPM.
Did you have the heads flow tested? Good move on going to the 2.125 intake valves and the higher compression JE's.
What fuel and carburetion are you planning on running?
Hopefully someone with a stock hood on a 69 can chime in and let you know for sure what intake heights will work for your car.
Old Apr 9, 2020 | 03:48 AM
I know for a fact a Torker and performer will fit under a stock 69 hood.
Old Apr 9, 2020 | 05:38 AM
Gene kerr's Avatar
I have a torker intake didnt know if there was a better option out there
Old Apr 9, 2020 | 05:44 AM
Gene kerr's Avatar
plan on running 93 if needed with a splash of 110 fuel and still have to buy a carburetor open for suggestions on that also
Old Apr 9, 2020 | 05:51 AM
66SportCoupe's Avatar
I personally prefer the airgap or if you want a single plane the Port O Sonic is better than the torker. That engine will want an 850 cfm carb. I like Demon carbs over Holley
Record4
Nov 11, 2023 02:17 PM
deadeyejedi
Apr 20, 2020 04:13 AM
chris83
Jul 19, 2019 09:12 AM
oregontopcat
Feb 28, 2011 12:11 PM
gearheads78
Jul 5, 2010 10:25 AM
