View Full Version : Big Blocks
- Random engine parts questions.
- Anyone have any stock 455 Dyno sheets?
- 70 tcs solenoid w30
- explain harmonic balancers for me
- Felpro 1356 intake gasket
- Manifold Torque
- Valve noise
- Oil pressure
- 394's exhuast set up??
- 394's bb or sb??
- 65-66 425 Valve cover swap?
- Mondello Valley pan
- update on the 455 build
- Oil thoughts/questions (accumulator)
- Valve Train Preload!!! HEAD SPINNING!!!
- Rocker Arm Ratios??
- Do I have correct fuel filter on 60 Olds 394?
- Need Help with Distributor
- HELP Shop or mechanic in SOCAL for my 455
- overheating your oil
- Loud noise from 425, running rough.
- Edelbrock Torker, your thoughts?
- Dart Heads
- 425 Question
- How do 455 GA heads rate?
- Help identifying Pistons (285-99 T, in upside down triangle
- 455 headers
- '66 442 with 425 engine
- Pictures of carburetor replacement
- olds 371 je forged pistons??? help
- Mysterious valve covers
- Where do I find a stock 4bbl intake manifold
- 330 to a 455
- decode d heads
- CN vs. N crank
- which trans?
- 66 442 Throttle return spring ?????
- 67 Cutlass w/ 455- Radiator issues need a 4 core
- Electric fuel pump mounting
- Oil pressure
- In search of a new radiator
- ? about intake manifold, HEI, and 4bbl on a 69 Delta 88
- Interchangeable intake manifolds
- Good 455 for my 71 Cutlass?
- 2 Barrel too 4 Barrel Carb Linkage??
- quadrajet 7042251
- 455 heads ?
- Aftermarket Chinesium 455 flywheel trouble?
- Bronze Dist Gear
- help 455 low compression pistons swap?
- Fair Price for 455/TH400
- motor mounts
- Switch from Street Dominator to Edelbrock O4B??
- flywheel bolts?
- what size or kind of carb?
- Av gas
- 394 rebuild help
- 394 fuel pump with vacum pump
- 750 qjet-2 questions
- 455 Intake Manifold Gasket
- 39* vs. 45* pushrod holes-B Head
- Off idle hesitation and rough running
- Hypereutectic vs forged
- What is this and why is it bothering me? The infamous leaking watervalve?
- Possibly going with a 455
- Cracks / advice
- Is $600 a fair price?
- Mystery Crank
- 350 to 455 conversion
- 71 455 Carb Question
- 455 Core
- 68 Delta 88 head gasket?
- Ka vs C heads.
- head questions
- How strong are the rods?
- holley street dominator or performer?
- anybody have photos of head work?
- does my 58 need a radiator fan shroud?
- 455 heads...
- 425 with 455 heads??
- 455 low to mid 12's (repost)
- carb identification
- Remove the thermostat???
- My 455 Build, est. HP?
- 400 bore
- after a good cleaning my cylinders look bad, going .060 over...
- repo radiators
- Good deal
- anyone recognize these pistons? anything good/bad about them?
- Starter heat soak on my 455???
- wanted misc parts recommendations
- looking for some clarification on 455 block manufacture year.....
- Question about thermostat housing
- 455 finally pulled
- N.o.s.?
- 455 Low-mid 12's on 1/4
- how do i calculate CID?
- knowlton thunder heads
- Good small block heads on a 455
- 425 Balancer
- Machine Shop(Central Texas or Dallas/Ft. Worth areas)who Specialize in Olds .
- stock cam identification?
- EFI - going to blow my own horn
- Why can't I tune my Q-Jet? Aka: I hate carburetors
- 425 vs 455
- Intake port question
- 455+motor mounts
- cooling system questions
- Intake manifold rear gasket sucking in
- 454 in olds cutlass ?
- 1967 425 - should I buy it?
- Old Style Rocket Valve Covers w/ Wire Loom
- Valve covers
- Best Fitting Headers for BBO in a 65 Cutlass
- 1.6 or 1.7 to 1 Ratio Roller Rockers
- Lifter choices
- optional oil return path ?
- question regarding dual exhaust
- Intake for 70 OAI hood
- Wanted
- 455 build up books or factory manuals, which ones?
- 455 what to look for
- 455 rebuild-minor detail
- 1970 Coil location
- Any one ever seen this?
- Valve Springs For Edelbrock Heads
- Will this Quad work for my engine?
- Availability of the 455, Present & Future
- Proper hose location
- Speed equipment for Oldsmobile
- 455 cyl sleeves
- Fuel pump question
- Ever heard of DUI distributors?
- torker intake
- which coil bracket to use
- Good source for blocks?
- Goodies for 455
- Magnum Roller rockers
- Under hood painting -- 1960 Olds
- Engine dies after idling!!!!
- HEI-- Which plugs and Gap?
- 455 Help
- Compatable Air Cleaner Housings??
- Anyone try a Tremic 5 speed?
- Should I replace Timing chain? newbie...
- 1965 425 starfire
- 66 toro motor spec.
- To See What I'm In F/ Pulled A Valve Cover
- motor in but oil on the floor?
- Just for fun ! Ultimate BBO what's yours?
- A little progress on my 455 need advice
- Is The 455 Harmonic Balancer good enough...?
- 425 question
- Help needed 394 Timing Chain
- 1978 Oldsmobile 98 Regency overheating problem
- 455 cid destributer removal
- Rochester 4gc carb help needed!!!!
- Big Block Intake Fitments
- Intake Manifold Casting Numbers
- Modification to Toronado pan
- Weird question about my intake manifold
- Rebuilt Q-Jet Woes
- 450 HP from 455
- Avoiding Oil Puddling In Lifter Galley
- Starter
- 1976 455 exhaust manifolds
- 69 400 lifter preload
- Slumbering 394 Won't Start
- 425 Engine Identification
- disturbuor for 455
- 68 olds 455 piston rings
- Question about roller rockers
- Camshaft engine 425
- 455 in a gbody
- Olds 455 with Crosswind Manifold/Hood Clearance
- valve cover oil leaking
- Some questions about electric choke
- New Harmonic Balancer Loose?
- cooling
- Getting the proper performance from a 455
- 1957 olds 455 engine
- Carb Help old 455, 71 cutlass, St. Louis, MO
- price for a 455
- olds 455 questions
- Z Exhaust Manifolds
- 400 or 455??
- why is the mtr getting blow-by?????
- 455 brackets(ac & alt)
- Holley Double Pumper
- Headers
- Carb and Intake For 455
- Headers for 394
- New Problem with my dad's 70 delta 88
- 455 Piston questions
- Fuel Pump
- Camshaft
- Gas tank?
- Good Article on Cam Events
- 455 vacum problem HELP
- Rod reconditioning
- Seasoned heads ..?
- Spreadbore vs. Square (holley and q-jet on stock intake)
- DMR 5058 exhaust gaskets
- Building a 455 stroker..........
- 400 Crank shafts
- Need temp gauge opinions
- 455 build
- 350 Vs 455.....What should it be?? (HELP)
- olds 455 rods and pistons
- cam choices. not so much daily drive as rice killer
- what is this hole for and how to clean it
- how much play in pushrods?
- sbo to bbo motor mounts
- 455 trouble--please help--
- swapping brackets from sbo to bbo
- gearing for a 455
- 455 quick question
- Balancing Motor
- 455 carb advise
- olds 455
- Alternator and bracket for '61 394
- building a 68 c head 455
- 61 starfire 394 losing coolant
- Spark Plugs for '67 engine 425
- Rebuild on a 371
- 68 Olds 455 ????????
- Electric Fuel Pump on a 66 Starfire
- water coming from choke plate on intake
- Holley carb question
- Lobe Sensor
- Starting the 64 without the trans in the car?
- Torker Intake Choke Block-Off Plate
- HEADERS & REAR END ?????
- crankshaft ?????
- Off His Rocker???
- what makes a BB a BB
- 455 Oiling System Question
- Vacume Advance probelms, 455cui, 4bbl 71
- possible swap. 350-455?
- 455 Intake Question
- info needed on my 68 heads
- Anyone know my compression ratio?
- from small block to big block help??
- ENGINE FROM 442 ?
- Fuel tank vents plugged.
- 455 Eng ID for Factory Horsepower Rating
- 1970 Cutlass S 455 project
- 455--425 water pump
- 455 Carb
