Anyone know my compression ratio?
Old Nov 30, 2009 | 03:45 PM
rtpassini's Avatar
I believe I have a 71 455 with Ga heads. (the heads were swapped)
Just curious what compression ratio I would have. Thanks!
Old Dec 1, 2009 | 08:31 AM
All BBO heads have about the same size chambers except for the D heads. CR was varied by changing the size of the piston dish. All 1971 motors were low compression (8.5:1 or 9:1).
Old Dec 1, 2009 | 12:12 PM
junior supercar's Avatar
not enough information. was the motor rebuild or not? need things like head gasket thickness, head cc (especially if heads were shaved), block zero decked or pistons in the hole? I could guess that it's anywhere from 8:1 to 11:1 but thats a big ballpark not knowing anything about your engine
Old Dec 1, 2009 | 03:59 PM
rtpassini's Avatar
100% stock.
back of the distributor is number 71
also found a 396021F
back by the flexplate is F4
Ga Heads (he said those were swapped out)
greenslade
Mar 29, 2011 03:56 PM
BlueBlock350
Apr 7, 2008 11:22 AM
OLD SKL 69
Jan 22, 2008 08:11 PM
Escalus2k4
Jan 15, 2008 08:29 PM
