ENGINE FROM 442 ?
Old Nov 29, 2009 | 06:03 PM
oldsmansugar's Avatar
ENGINE FROM 442 ?
I have a 69 400 motor. Is there any way I can tell if its from a 442 ?
Old Nov 29, 2009 | 06:07 PM
2blu442's Avatar
Is it complete? The carb and distributor would have numbers showing the application, but I'm not aware of anything on the block that would show it. I do know 400 engines were used in Vista Cruiser wagons, I don't think they were used in any of the full sized cars. I'm sure others will add more to clarify this for you. John
Old Nov 29, 2009 | 06:12 PM
rcorrigan5's Avatar
Randy C.
Is the intake manifold for a 2-bbl carburetor or a 4-bbl carburetor? If it's a 4-bbl, it's definitely a 4-4-2 engine. If it's a 2-bbl, it could be a 4-4-2 turnpike cruiser car or a vista cruiser station wagon with the optional 400ci engine.
Old Nov 30, 2009 | 09:38 AM
The 2bbl Turnpike Cruiser in the 442 was 1968, not 1969.
The reality is that there is probably no way to know for sure if the motor came from a 442 or a Vista. You can tear it apart and check the valve sizes and cam profiles. Just keep in mind that these items can be changed.
Old Nov 30, 2009 | 05:54 PM
4bbl complete
The engine has a 4bbl carb . It is complete and all original as far as I know. I have it in a 70 cutlass conv. Just got it running and installed a electronic ignition.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
