disturbuor for 455
Old Jan 25, 2010 | 07:32 AM
airlamb's Avatar
disturbuor for 455
i got a 76 455 without a disturbour will a dist. from a 1982 4.3 V8 work?
Old Jan 25, 2010 | 08:42 AM
I assume you're talking about a 260 Olds V8. That distributor will physically fit, but it will only work with the CCC system (unless it's off a Canadian car). If the distributor has a vacuum advance canister, it will work (though you will want to change the mechanical and vacuum advance to match your engine's requirements). If it does not have a vacuum advance canister, it will only work when hooked up to the computer.
Old Jan 25, 2010 | 10:09 AM
You can get a stock replacement distributor reasonably at your local auto parts store.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
