455--425 water pump
Old Nov 25, 2009 | 03:35 PM
AZ442's Avatar
455--425 water pump
Need a little help with my water pump. I have a 425 D block and need to replace the water pump. Can I use a 455 pump as long as the lengh of the shaft is the same? Are they interchangable?
Old Nov 25, 2009 | 05:03 PM
2blu442's Avatar
Yes they are.
Old Nov 25, 2009 | 06:14 PM
All 1964-1990 Olds V8 motors (except the 1964 394) use the same front cover and thus can interchange water pumps. As you note, length must match. Also, there are some with only one fitting on top for the t-stat housing bypass hose and others with two (one for the heater hose also). The 1964 pumps are one-year-only and have the inlet on the driver's side. And the V-6 diesels used a reverse-rotation pump for a true serpentine drive.
Old Nov 25, 2009 | 07:52 PM
Run to Rund's Avatar
Length is determined by the car not engine; there are 5.12, 5.59" and 5.95" heights.
Old Nov 26, 2009 | 04:23 AM
Yes, though actually the car AND the application (A/C or HD cooling vs. non-A/C).
Old Nov 26, 2009 | 07:18 AM
AZ442's Avatar
Thanks for the help,. I will match the pump before buying a new one. I do have HD cooling and AC.
Nor Cal Andy
Mar 29, 2012 07:27 PM
oldsonharmont
Jun 22, 2010 09:41 AM
longboardguy
Jun 25, 2009 04:48 PM
72Ctlss
Jun 23, 2009 03:12 PM
greener_dude
Feb 18, 2007 08:14 PM
