455--425 water pump
455--425 water pump
Need a little help with my water pump. I have a 425 D block and need to replace the water pump. Can I use a 455 pump as long as the lengh of the shaft is the same? Are they interchangable?
All 1964-1990 Olds V8 motors (except the 1964 394) use the same front cover and thus can interchange water pumps. As you note, length must match. Also, there are some with only one fitting on top for the t-stat housing bypass hose and others with two (one for the heater hose also). The 1964 pumps are one-year-only and have the inlet on the driver's side. And the V-6 diesels used a reverse-rotation pump for a true serpentine drive.
Nor Cal Andy
Mar 29, 2012 07:27 PM
