info needed on my 68 heads
Old Nov 30, 2009 | 08:01 PM
steve walker's Avatar
swat455
hi when i first got my 68 455 mtr it was in a delta custom that i wrecked anyhow its type c .now on the orig air cleaner it did say ultra high comp are these the large valve heads????
Old Nov 30, 2009 | 08:09 PM
2blu442's Avatar
I'm not an expert with the Delta Custom, the only way I know of checking is to pull a head and measure the intake valve. There was no external marking on the heads to indicate small or large valve. I believe it was the application that made the determination. 442's and Toronado's got big valves, I'm not sure what else did. John
Old Dec 4, 2009 | 09:48 PM
64Rocket's Avatar
Between the 2.00" or the 2.07" valves is not a big difference for a street car. You would not be able to tell the difference. The machine shop can install the big valves if you want, a very easy installation. The biggest improvement with either valve, would be the 3 angle valve job.
Gene
69OLDS455
Feb 25, 2011 04:37 AM
frasco
Aug 27, 2010 03:10 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
rickbmac
May 26, 2010 03:45 PM
