what size or kind of carb?
Old Mar 23, 2010 | 09:35 AM
dgreen's Avatar
hi i have a 72 455 out of a toronado im refreshing and i changed a few things just wondering what carb would work best budget is getting tight but i want something that will work good. heres what i got so far Ga stock heads small valves rv cam torker manifold its going in a cutlass with 3;42 gears flowtech headers no ac thanks 71 cutlass s
Old Mar 23, 2010 | 05:17 PM
cutlassefi's Avatar
IMO, ditch the Torker, wrong manifold for the "RV" cam and small valve heads. Buy a used Performer somewhere along with a Holley or Edelbrock carb with about 750cfm.
Old Mar 24, 2010 | 09:12 AM
dgreen's Avatar
thanks i will keep my eyes open i gave a 100 bucks for the torker so its not too big a hit i might be able too use it sometime down the road
Old Mar 25, 2010 | 04:10 PM
compedgemarine's Avatar
agreed on the torker. you need to be able to spin the motor up pretty good to make it work and the cam is going to want to work in the low rpm. put the word out and you may find someone that wants to swap for a performer.
Old Mar 26, 2010 | 06:18 AM
dgreen's Avatar
thanks im gonna hit a few swapmeets and keep an eye on ebay for a performer
Old Mar 26, 2010 | 07:34 AM
Warhead's Avatar
Ok on the Torker, but neither the Holley, nor the Edelbrock carburetors can compare to the Q-jet.
The Q-jet will always have a 2mpg advantage over these other carbs, and will only be down on power to an 850 Holley-only because of sheer size.
BTW, part throttle response will be better with a Q-jet.
The only way to improve over a Q-jet is with fuel injection-ask Mark about the cost involved there.
Jim
Old Mar 26, 2010 | 08:48 AM
cutlassefi's Avatar
Q-jet is fine too, just forgot to mention it.
Multiport EFI runs about $3500.00 for a big block, about $2500.00 for a throttle body.
But I have it on mine, wouldn't trade it for anything, JMO.
Old Mar 26, 2010 | 09:08 AM
dgreen's Avatar
ouch!! no fuel injection here i am tryin 2 keep it simple thats what i love about these cars i have a couple q-jets layin around mabye i can rebuild one thanks
Old Mar 27, 2010 | 05:42 AM
BIGJERR's Avatar
I bleed Oldsmobile
My Torker worked just fine on a 8.1 smog motor running low 13s USE IT..........I would say a 750 vacum holley or maybe a 650DP I think a 750DP holley might be a tad much,I have never had good luck with Qjets mostly becauce there all wore to shyt by the time I got them and every machine or performance shop has Holley parts.......Jerr
72Cutlass
May 24, 2021 07:24 AM
The_Jeremiah
May 9, 2008 05:54 PM
BIGJERR
Jan 22, 2008 07:19 AM
GoldOlds
May 20, 2007 09:17 AM
