Intake Manifold Casting Numbers
Old Jan 30, 2010 | 07:19 PM
oldsonharmont's Avatar
I need the casting numbers for a factory 4bbl intake manifold for an Olds 455. Looking for 1970 - 1971 non-EGR with the choke stove, many thanks.
Old Jan 30, 2010 | 07:32 PM
2blu442's Avatar
My reference book shows:
1970-72 4bbl Automatic Transmission 404521
1970-71 4bbl Manual Transmission 407567
John
Old Jan 30, 2010 | 07:35 PM
JRVintage's Avatar
1970-71 cast iron MT 407567 1970-72 AT cast iron 404521
Old Jan 30, 2010 | 07:38 PM
scott_442's Avatar
What's the difference in an intake for an AT vs. an intake for MT? Are they interchangable?
Old Jan 30, 2010 | 11:56 PM
Many thanks for the help with those numbers! Sorry I don't know the difference between the two intakes but I'm willing to bet someone here does.
Old Jan 31, 2010 | 05:56 AM
Warhead's Avatar
The difference is probably just the number on it. Interchangeable-yes, but not for a number correct car.
It would be nice if there was a deeper plenum, or more runner volume on the 4 speed unit.
According to my Mondello manual, the part #413111 (1973 455 4 bbl with egr) had a slightly larger "flow area" (2.68, as opposed to 2.50...whatever), as compared to the other non Toronado intake manifolds made by Oldsmobile.
Jim
Old Jan 31, 2010 | 09:11 AM
The difference is that the MT intakes have the fitting for the PCV valve, like the W-30 intakes. The AT intakes do not.
Old Jan 31, 2010 | 07:07 PM
Picked up my intake today, a very clean original piece and the correct number (404521) casting for my application! Thanks again for the help with getting the correct casting numbers!
Old Jan 11, 2018 | 06:41 AM
Domo's Avatar
intake manifolds bolts
HI In a related subject, I have a stock 1970, 455 Oldsmobile intake manifold and I purchased some bolts from Mondello's. There are three different sized bolts in the package. Question is, do you know there is a bolt pattern for these longer bolts go or should they will be the same size?
Old Jan 11, 2018 | 07:17 AM
No, actually the bolt lengths really aren'r related to an eight year old thread on casting numbers...
In any case, a stock iron 1970 intake should use bolts that are all the same length. Depending on your accessory brackets, you may or may not need one or two bolts with a threaded stud on the head. In some cases, the intake may be thinner at the bolt locations on either side of the heat crossover in the center of the intake. If so, use the shorter bolts there.
Old Jan 11, 2018 | 05:14 PM
Domo's Avatar
Thank you for the information, this is what I was thinking, but the intake manifolds is off at the powder coders and I can not confirm.
Old Mar 12, 2018 | 05:24 PM
Since we're dredging up an old thread here, I noticed the letter 'L' cast along the front runners on this 404521 intake. I'm asking if that's significant because the stock heater control valve had to be adapted to fit the 1/2" threaded port. Everything works as it should, I'm just curious what intake I ended up with here.
Old Mar 12, 2018 | 06:30 PM
tru-blue 442's Avatar
Old School Olds
L intake is for a 70.
Old Mar 21, 2018 | 06:48 AM
rick@lindaleautoparts.com's Avatar
I have been told that an edelbrock performer 2151 is too high to fit under the hood of my 67 olds 442 any body know for sure
halfmoontrail
Jan 25, 2016 06:47 PM
Nickyloves442s
Oct 24, 2012 04:55 PM
delta881972
Aug 24, 2008 09:19 PM
paige_dart
Nov 12, 2007 09:40 AM
omega73
Aug 17, 2006 07:24 AM
