Rebuild on a 371
Old Dec 12, 2009 | 10:56 AM
317rcampbell's Avatar
Rebuild on a 371
I have a 1957 Oldsmobile 98 with a 371 in it. It only has 28000 miles on the motor and has been sitting in a garage for 30 years . I pulled the motor and started taking the motor apart. The motor was locked up , I have all the pistons out but one that looks to be stuck. I think I am why over my head on this and was wondering if I took it to a shop what do you think it would cost to rebuild it.. Thanks and Hope all you Oldsmobile owners have a great Holiday
Old Dec 12, 2009 | 10:58 AM
I would try to use a rubber hammer and try and tap it out but I cant get to the bolt thats is holding it
Old Dec 12, 2009 | 11:03 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Before disassembling a weather stuck motor, you should get all water off of the top of the pistons if there is any, and fill the spark plug holes full of trans fluid and let it sit. Eventually, the rust and varnish will break up and you can turn it.
Old Dec 12, 2009 | 11:06 AM
Thanks , But I did soak it all in tranny fluid and even tried blaster , I let it set for about a month and it still wont move. I even flipped the motor over on the stand and tried soaking it from the bottom.. Still no luck
Old Dec 12, 2009 | 11:34 AM
Wow.
Sledge hammer?
I seized a rod bearing so bad once that I had to use a sledge hammer on the counterweights to turn the rotating assembly.
Believe it or not, I gave the mangled mess to Steve-o on here, and he runs 9.40's with my old block. Happy ending to that motor's life story.
Old Dec 12, 2009 | 12:02 PM
Ross Racing Engines's Avatar
Give me a call as we specialize in early Olds
Tony
Ross Racing Engines
1763 North Main St
Niles,Ohio
44446
330-544-4466
330-720-1282 c
Old Dec 12, 2009 | 12:07 PM
Sorry I thought I had a signiture on this board
Added it
Old Dec 12, 2009 | 12:08 PM
Tony,
When is a good time to call you
Old Dec 12, 2009 | 12:19 PM
If Im not at the shop I still answer my cell up till midnight Ohio time
If I dont answer leave a message and Ill ph back relitively quick
Tony
Old Dec 12, 2009 | 12:57 PM
J is correct. Automatic transmission fluid or diesel fuel will usually unsieze a frozen engine. If you contact Ross Racing I am sure they can help if they know their stuff. You should be able to get engine internals from Kanter. Unfortunately, aftermarket parts for the early Olds engines are scarce.
FWIW, I just rebuilt my 455 last year and I spent about $3000 on all of the machine work and aftermarket parts I bought. I bought an aftermarket intake, HEI distributor, camshaft, oil pan, rocker arms, and timing chain.
Old Dec 12, 2009 | 01:09 PM
I have stock and speed parts for the early Olds family
as well as trans adaptors auto and stick
we are devoloping new stuff all time
I've got enough new items that you can build an early Olds using just the
bare block and a few odds and ends
and I also do restoration type blueprinted engines and everything in between
Tony
Old Dec 12, 2009 | 01:13 PM
That is AWSOME Tony! Too bad I didn't have the means years ago to trick out my 1964 Olds 98 with a 394. I did some engine work to it and drove it through college but ended up selling it last year because it was just too far gone. Those early Olds engines are cool!
They even make valve covers for SBC engines that emulate the older Olds engines (I think the 303)!
Old Dec 12, 2009 | 01:42 PM
I do build all aluminum chevy race engine also ,but I refuse to put those olds looking covers on a chevy to build a fake olds.......we have lots of products but those aren't ours
Always gotta be what ya are!!
Tony
aarondb4
Mar 7, 2014 12:05 PM
1957 Super 88
May 30, 2013 10:47 AM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
