39* vs. 45* pushrod holes-B Head
Old Mar 19, 2010 | 07:34 PM
jc83's Avatar
hellllooo...any way to verify the angle of pushrod ??? i cheated & stuck large threaded rods (3/8") into the pushrod hole of my B head & did the same to my #6 350 head.. lined "em up & they both visually were the same..i dont know if this is truelly legit but hopefully it is...of note to any who think the 65 B Heads were all 45* think again... i found an OLDS site where they were talking about all the different lifter sizes & bank angles degrees etc..quite a bit of the 425 motors got the more modern 39* angle than u may realize in 1965 ,66..thanx for your input & help..now get out there & rip up the road !!
Old Mar 19, 2010 | 07:49 PM
2blu442's Avatar
I thought I had a good post that would help you... but realized I didn't. If you have the time try the search option and read through the threads you find. John
Old Mar 20, 2010 | 06:24 AM
Red Delta's Avatar
Registered Abuser
I stole this off of another thread around here somewhere. I'm too lazy to find it to give credit to whoever posted it...
Old Mar 20, 2010 | 05:48 PM
jc83's Avatar
ya i dont have the block just the B Heads...i think there may be some engine id # stamped on the right front head but i dont know if it will help...one site i was reading was blabbing about some kind of dowel pin hole/spot on the backside of the block that would indicate wether 39* or 45* depending on location of said spot..but im otta luck on that option...i lined my 2 heads up like a gunsight when i did that cheater method just running it by u guys to see if its legit or works..
Old Mar 20, 2010 | 05:59 PM
Red Delta's Avatar
Registered Abuser
I don't know about that for sure. I have 'B' heads on my 45 degree block.
Old Mar 20, 2010 | 07:02 PM
ent72olds's Avatar
Registered Luser
I have B heads on my 39deg '66 Toro engine #N687578T(head stamp)....
Old Mar 20, 2010 | 07:08 PM
wmachine's Avatar
Trying to remember member
'65 B heads???
Old Mar 20, 2010 | 08:22 PM
Red Delta's Avatar
Registered Abuser
Dang it, now I have to go out see what my stamp says...
Old Mar 20, 2010 | 08:40 PM
2blu442's Avatar
Doh! Kurt, I didn't even catch that the B heads were identified as 1965. jc83 if you have B heads they're from a 1966 not a 1965. John
Old Mar 21, 2010 | 08:49 AM
aliensatemybuick's Avatar
"me somebody" site member
I noticed the '65 B head thing, but figured I'd cut the OP some slack.
Old Mar 21, 2010 | 10:03 AM
copper128's Avatar
Lt. Buzzkill (ret.)
...one site i was reading was blabbing about some kind of dowel pin hole/spot on the backside of the block that would indicate wether 39* or 45* depending on location of said spot...
That drill spot is on the front of the block - the rib above the timing cover flange. It is a reliable indicator of a .921" lifter/39 degree block.
You can see it in this photo:
Old Mar 22, 2010 | 04:33 PM
jc83's Avatar
hi ..so sorry about 65 vs. 66 B heads...that was me reading that olds info tech site that was talking about heads & years they were used...so anybody out there have both types of heads 39* 45* and could u do me a big favor just line em up like a gunsight like i did & tell me if there is a huge descrepancy/ noticeable difference in angles of rods sticking out of your pushrod holes..thanx for your time & help --jc--
RAMBOW
Brakes/Hydraulic Systems
Feb 2, 2015 05:07 PM
Warhead
May 31, 2011 01:24 PM
Cari43
Nov 20, 2010 09:21 AM
Cari43
Nov 2, 2010 03:51 AM
54olds
Mar 31, 2008 06:07 PM
