Holley carb question
Old Dec 6, 2009 | 02:41 PM
fmay50's Avatar
Question Holley carb question
I have a 750 double pumper with mechanical secondaries and 4 corner adjustment. Carb is brand new and bolted on out of the box. My problem is idle. It is fine until engine reaches 190 degrees and then idle go up considerably. There is also the smell of fuel after engine is turned off. Any thoughts?
Old Dec 8, 2009 | 02:20 PM
Did you set the idle speed and idle mixture screws properly?
Old Dec 8, 2009 | 02:40 PM
BosMobile's Avatar
Ck float levels as well
Old Dec 9, 2009 | 02:11 PM
I would be pretty upset if I bought an aftermarket carburetor that required extensive adjustment. Hopefully you get it figured out easily. Keep us posted.
Old Dec 9, 2009 | 02:54 PM
fmay50's Avatar
I'm going to adjust on it tomorrow. I'll let you know. Thanks for the help.
hawks70
Jun 17, 2013 10:45 PM
delta881972
Jan 24, 2009 05:54 AM
Wasted
Jan 19, 2009 07:53 PM
