Magnum Roller rockers
Old Feb 9, 2010 | 08:33 AM
1964f-85's Avatar
I just installed Magnm roller rockers, guide plates and pushrods in my 68- 455. Has anyone had experience with these (good or bad) also any tips for setting the preload would be helpful
Old Feb 21, 2010 | 02:14 PM
Mongoose's Avatar
Funny you haven't had any response on this. I've got a set of the Comp Cams stainless roller rocker arms bolted up... but I can't give you any feedback on them yet... the motor hasn't been run yet.
Old Feb 21, 2010 | 03:53 PM
Its a decent set-up, they wont handle much valve lift or spring pressure. If they wont handle your cam profile then you need to move up to 3/8 screw in studs and full roller rockers anyway. In any case, pitch the pivot nuts that come in the kit and get a real set of polylocks with setscrews to lock the adjustments.
As far as valve lash, start with cylinder #1 at TDC (both lifters should be on the base circle of the cam). Slowly tighten the polylock until you get zero lash (lifter plungers has no preload, but no clearance). Turn the polylock 1/2 to 3/4 turn, then tighten the setscrew. Rotate the engine 90 degrees, lash the valves on cylinder #8. Rotate 90 degrees and #4, continue rotating 90 degrees and lash the valves in the same sequence as the firing order.
Old Feb 22, 2010 | 12:25 AM
64Rocket's Avatar
For me, I would never turn the polylock 1/2 to 3/4 turn. For me 1/4 turn at the most.
Gene
Old Feb 22, 2010 | 04:18 AM
380 Racer's Avatar
^^^^^^ I agree.
Old Mar 4, 2010 | 11:10 AM
1964f-85's Avatar
Thanks for the imput, I will start at a 1/4 turn and work from there. I didnt get the poly locks, if I run into trouble I'll change them out (I was concerned about the addtional height of the poly lock). I have an old steel valve cover, I am going to cut off the top so I can adjust the valves with the motor running like a small block chevy.
2oldsguy
Apr 9, 2014 04:21 PM
tomngary
Aug 20, 2013 09:34 AM
timothypaul
Oct 26, 2008 08:03 PM
Redog
Aug 14, 2008 06:56 PM
70OLDS442
Nov 21, 2007 05:00 PM
