olds 455 questions
Old Jan 12, 2010 | 10:17 AM
airlamb's Avatar
olds 455 questions
I am looking to get a used olds 455 block for rebuilding... what are some things i should look for... what blocks, heads are better etc.... casting marks? i will be putting it in a 66 f-85 four door... want to put a turbo 400 behind it.... i dont need anything crazy for power just dont want to get the worst one ....where are the casting marks on the block and heads at??
Old Jan 12, 2010 | 10:53 AM
http://www.oldsmobilewiki.com/index....gory:Top_level
Read the sections on "Engines", "Blocks", and "Heads" for more info.
Keep in mind that the last 455 Olds was made in 1976. Unless you plan to pay big bucks, you will likely end up taking whatever you can find. The 73-76 smog motors are by far the most common and will make a perfectly acceptable foundation for your build. The J heads used on those motors are not desireable for all-out performance, but with some mild port cleanup they will make excellent, torque-producing street heads.
If you do manage to score an earlier motor, all the better, but don't kill yourself looking for one.
69oldsdelta88armyvet
Apr 27, 2014 01:02 PM
76 Regency
Oct 16, 2012 01:56 PM
1970Olds442
Aug 19, 2012 10:19 PM
526 turbo
Oct 15, 2009 11:13 AM
Rusty Bucket
Jul 22, 2007 10:52 AM
