425 Balancer
Old Feb 25, 2010 | 04:17 PM
VegasDelta's Avatar
425 Balancer
I'm going to replace the harmonic balancer on my '66 425. I'm not sure if it needs one specific to that engine or will a 455 balancer work as well? Thanks.
Old Feb 27, 2010 | 02:48 PM
silverriff's Avatar
1972 Cutlass 455
I replaced the balancer on my 455 recently with a Dorman...from what I could find it was the very cheapest you can buy. I got mine at my local mom and pop shop for about $90.00 but if you go to Rockauto.com, I believe you can get it even cheaper. As for the application, the one I got was correct for a ton of different makes, models, and years all the way up to 1995. So I am about 90% sure it would work for what you need. If you go to rockauto, or to the Dorman site, they will let you know. Or give their tech support a call, they were extremley helpful and knowledgeable and spoke English too! No offense!
Old Feb 27, 2010 | 02:57 PM
copper128's Avatar
Lt. Buzzkill (ret.)
The 455 balancer won't work. Pre-'68 engines had different balance.
Consider having your original rebuilt by DamperDoctor.com, you won't be sorry.
Old Feb 27, 2010 | 03:07 PM
380 Racer's Avatar
What makes you say that?
Old Feb 27, 2010 | 03:19 PM
2blu442's Avatar
Visually I know they're different. The 425 is much smaller than the 455. But I don't know the effects of putting on a larger one. I have seen several different sizes on 350's from 1968-72, and I don't know the rhyme or reason behind it. John
Old Feb 27, 2010 | 06:49 PM
silverriff's Avatar
1972 Cutlass 455
Yeah I just checked Dormans, the balancer I used says it only goes back to 1968. According to 442.com, the 66 425 shouldn't be swapped with a 455 balancer, but it doesn't say it can't be used. I would probably do like Copper said and just send your old one to the Damper Doc. Play it safe.
Old Feb 27, 2010 | 06:53 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Actually Nick, i don't know that. but I do know the balancers and flywheel/flexplates are different. Whether the size and weight of balance weights is different, I don't really know.
Old Feb 27, 2010 | 08:17 PM
380 Racer's Avatar
OK, thanks. Thought maybe there was something specific that I didn't know about.
Old Feb 28, 2010 | 10:01 AM
VegasDelta's Avatar
Thanks for the replies. Guess I'll look into getting the old one redone.
Old Mar 2, 2010 | 10:12 AM
Run to Rund's Avatar
Diameter, width of ring, position of timing mark differ 67-back and 68-up. The overall thickness from the crank timing gear to the pulley surface are the same, and the pulley bolt pattern in the same. So, you could use a 455 balancer if you got it rebalanced to the earlier amount of counterweight, and used the later timing pointer.
Moose2
Oct 18, 2012 07:28 AM
bisscrac
Jun 8, 2012 10:12 AM
2blu442
Jul 16, 2010 07:26 AM
ijasond
Aug 21, 2009 06:29 AM
Steve O
Dec 12, 2008 09:22 AM
