Alternator and bracket for '61 394
Old Dec 14, 2009 | 05:32 PM
Starfire1961's Avatar
Question Alternator and bracket for '61 394
I am looking to remove the stock generator off my '61 394 and use a modern GM (1) wire alternator around 75 amps. Is this do-able or can I use an alt from a later 60's Olds? thanks.
Old Dec 15, 2009 | 08:18 AM
Run to Rund's Avatar
Some 62s had an alternator, and iirc all 63s.
Old Dec 15, 2009 | 08:28 AM
Thanks do you know if it is a direct bolt on?
Old Dec 15, 2009 | 10:32 PM
59-59-59's Avatar
I tried using alternator brackets off a 62 394 and put them on both a 59 and 60 394 and it does not work.. There are no holes in the earlier heads to directly bolt on later alternator brackets. I ended up using the stock generator arm and a cheap chevy alternator base mounting bracket ( minor fabrication) and used a GM 1 wire alternator
Old Dec 16, 2009 | 05:28 AM
Thanks 59-59, do you have any pics of what you did? Sounds like a good idea, and also which amperage alternator did you go with-from what year and model Chevy? thanks.
Old Dec 18, 2009 | 12:11 AM
59-59-59's Avatar
I went with a universal 1 wire GM alternator ( not too sure of amperage ) and just a universal bracket that can be found in the Summit catalog
Old Dec 20, 2009 | 08:00 AM
KQQLCAT's Avatar
Okay I have a alternator bracket I bought in case I wanted to do this down the road on my 61 Olds 394. I read the posts so I checked my head for the holes and they are there. So I can only assume they changed the heads in 61. So to answer your question yes you can use the bracket. Two of the holes are being used by the generator bracket already.
Pat
442mark
Sep 30, 2017 01:06 PM
INTRUDER
Nov 15, 2015 08:01 AM
INTRUDER
Sep 21, 2012 05:36 PM
xerxes600rr
Aug 30, 2011 06:43 AM
Natas
Nov 15, 2007 05:42 PM
