swapping brackets from sbo to bbo
Old Dec 20, 2009 | 02:24 AM
procharged70cutlass's Avatar
i was told that i could use all my brackets and pulleys from my 70 350 on the 68 455 that i have . does anyone know this to be true
Old Dec 20, 2009 | 05:06 AM
crazy'boutOlds's Avatar
Sounds right to me. I did it on my 455 swap.
Old Dec 20, 2009 | 06:49 AM
70 cutlass s's Avatar
Yes the brackets inner change.
Old Dec 20, 2009 | 02:06 PM
Since I just watched Blazing Saddles recently, "It's twue, it's twue".
Of course, there's a "but". You must use the brackets, pulleys, and matching length water pump as a set. There are three different length Olds pumps, and the pulley offsets are different to match. If you also take the pump off the 350, you'll be fine.
Where brackets either bolt only to the head or only to the block, there is no difference due to the BBO's taller deck height. Where the bracket spans from the head to the block (one example is the non-A/C alternator bracket top piece) then there are two sets of holes to accommodate both deck heights. The alternator bracket I noted has two holes where the small strut that goes to the water pump bolts to the "Y" shaped upper bracket. The hole closest to the alternator is for the SBO, the other for the BBO.
olddaz
Aug 27, 2014 06:39 PM
TripDeuces
Feb 22, 2012 08:43 AM
import extermination
Oct 13, 2011 04:08 AM
GoldOlds
Jun 11, 2007 04:21 PM
