PDA
View Full Version : Big Blocks
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Plug interpretation
  2. Before or after?
  3. 425 build head/ head gasket questions
  4. Source for front cover stud
  5. Cam Advice wanted for mild 455
  6. 455 Cylinder Head production date
  7. Rocket Racing in Wisconsin
  8. New Engine for a GMC Motorhome
  9. Carb Advice Needed
  10. 58 dynamic 88
  11. Low RPM HEI misfire - got it!
  12. Rocker Shims
  13. Drinkin' Like A Boozer
  14. 455 rebuild
  15. 73 455 edelbrock 1407 750 carb throttle issue
  16. Offenhouser intake
  17. 75-76 455 timing chain set
  18. Starter motor issue ?? 455
  19. Drilling crank for Stick question
  20. Gaskets or No Gaskets
  21. 58 dynamic 88
  22. Supercars Cam for 1965 400
  23. supercars
  24. 394 oil pan seal
  25. Can't get my 455 to start.
  26. New timing cover crank seal won't stay put
  27. Fixed fan with no clutch on my 73 455
  28. 260 to 455 swap in a 1977 is done.
  29. Carb Change
  30. Summit harmonic balancer question 🤔
  31. Looking for timing card info for Mondello JM-20-22 cam?
  32. Dead spot on acceleration 🤪Fuel problem!
  33. 455 Piston pin Spiral lock installation tool
  34. Oil Leaking at Distributor
  35. Fuel pump problem
  36. Vacuum advance recommendations please
  37. 64 394 Spit Bearings?
  38. Q-JET CFM 78 Delta 403 ?
  39. Replacing carburetor
  40. You Guys were right!
  41. White smoke from exhaust - smells like fuel
  42. Header advise
  43. 394 cam bolt
  44. 1967 400E forged pistons
  45. 455 rear main cap sealer
  46. Flooding in the engine room (aaaaoooogah!)
  47. pulleys
  48. Another 455 build qusetion
  49. Help with 750 Quickfuel slayer carb.
  50. Q jet
  51. Think I made a hose mistake
  52. Oldsmobile with EFI and Edelbrock
  53. 1962 Delta 88 poor start, flooding every crank?
  54. Are ICON good pistons?
  55. 455 Long Block Help
  56. 455 arp main stud kit
  57. Rochester 4gc idle mixture set.
  58. 425 additions
  59. Cam?
  60. 400 Engine oil pressure problem
  61. 455 Oil pan removal
  62. 64 394 Rocket Air Cleaner?
  63. 455 Ring gaps
  64. Parts that need to be identified
  65. 394 Unknown Engine plug
  66. Engine Transport from Spokane, WA to Portland, OR
  67. Small whistle with RPM
  68. 394 possible valvetrain issue or ?
  69. Drilling enlarging push rod holes in C heads
  70. Oil control issue
  71. Main bearing question
  72. Need help identifying carb mechanism
  73. Help! 394 main bearings not found!!
  74. Tips for making a 2 piece timing cover
  75. Pro Gear timing gear set
  76. Stock Rod Limits
  77. Junkyard serpentine?
  78. Errors with timing chain and balancer
  79. Trying to ID a 455
  80. Engine woes
  81. Fuel Pump Question
  82. Carb Gas Leak
  83. Edelbrock 1406 in a 455 ????
  84. '68-'69 OAI Air Cleaner Differences?
  85. Endangered Species: hyd roller lifters ?
  86. Timing with Pertronix
  87. 394 burning too much oil?
  88. 455 in a 1977 update
  89. New 425 oil pan ?
  90. Head Replacement
  91. Can this block be saved?
  92. 455 or 350 in an 82 cutlass?
  93. I got a good deal on Big Block Springs so...
  94. Another 455 swap advice thread
  95. Oil Pan Suggestions
  96. Cam thrust button clearance
  97. A matter of timing...
  98. Should I leave well enough alone? 🤔
  99. Drivability, Tuning, Vacuum problem.
  100. Can This Carb be Saved?
  101. 455 adjustable rocker recommendations
  102. Horsepower??
  103. 64 Oldsmobile 394 E-85
  104. Carb backfires under hard acceleration from a stop...why?
  105. 1965 Heater hose and fitting?
  106. Crankshaft Seal (?)
  107. Parts brand recommendation
  108. Factory throttle cable and bracket question 🤔
  109. Whats wrong with this picture ??
  110. 455 machine work done, moving forward
  111. 1972 442 Carburetor issues
  112. Decode 455 stamping
  113. Replacing exhaust manifold gaskets
  114. whats redline?
  115. Engine mount question for a 1977 455 install
  116. 455 running rough, video
  117. Won't start easily when warmed up
  118. Upgraded Valve Springs Engle 2720H
  119. Rocker arms
  120. 1968 4-4-2 Radiator Research: Tank IDs, etc.?
  121. Compression ratio info wanted
  122. 394 Main bearing similarites?
  123. Cam Brand for the 394?
  124. 69 400 BB compression
  125. Crank socket
  126. Coolant streaming ot of back of the engine
  127. 455 Olds wont hold fuel in upper fuel line.
  128. Cam Thrust Washer
  129. .080 head gasket
  130. 71 455 hodge podge
  131. 69 442 Qjet Carb
  132. Vacuum Hose Routing
  133. 1967 400E with 1965 A Heads
  134. Grant piston rings
  135. Rod bearing clearance .0012 ??
  136. Sealant on brass engine components and dipstick?
  137. Compression Ratio, Octane & Elevation
  138. Will this work?🤔
  139. Harland Sharp roller rockers, which valve cover?
  140. Rod bearings and metal on metal
  141. full roller rockers
  142. Deformed intake gasket
  143. Need Help...Vacuum Leak and I'm going Nuts!!
  144. Low Vacuum
  145. Smoking after sitting
  146. What's this thing?
  147. Dipstick
  148. In regards to boring out the cylinders...
  149. Valve cover gasket replacement?🤔
  150. School me on the 400
  151. Best place to get a aluminum 4 core radiator?
  152. Any modified 394s?
  153. Looking for Aluminum Heads for 455
  154. Edelbrock heads / Versus Oldsmobile E or C heads?
  155. Dual Snorkel Air Cleaner
  156. Best valve cover gaskets?
  157. Oil Dipstick
  158. 71 CS 455 with Performer/Qjet NO OAI
  159. Engine falls on its face on hard acceleration/help???
  160. 455 vs 425
  161. L2323F Pistons?
  162. missing
  163. Good oil used?
  164. Feedback for 455 rebuild plan
  165. Broken bolt
  166. 425 Pushrods -67 Torornado block and A-heads
  167. Radiator over flow tank OPGI V Fusick??
  168. 455 W30 build
  169. Oil Pump High Pressure Spring
  170. Used Engine Precautions?
  171. 455 Rebuild for Nascar/Roadkill Cutlass
  172. W-32 Camshaft
  173. 19/32 core plug
  174. Which intake?
  175. Hooker 1 7/8 header 455 dipstick
  176. 68 442 with 390925E Block Casting
  177. Scuffed Cam Bearing: Input Please
  178. Cam selection...455
  179. Balancer Slides on by Hand, Engine Making Noise ?
  180. Running 455 - 460HP - Worth $
  181. Is it okay to T vacuum components?
  182. Newbie from Ohio engine id
  183. 68 455 rattle
  184. 455 oil pressure/pump replace
  185. 394 Alternator.
  186. 455 crankshaft specs
  187. Vendor recommendations for 455 parts
  188. 1963 Olds 98 conv motor mounts?
  189. 394 Rocker Arm Shaft
  190. 455 Crane High Intensity Lifters Part 2
  191. 455 heat riser shroud
  192. 455 Crane High Intensity Lifters
  193. 425 cam questions
  194. Chewed Up Lifter
  195. Plan to replace oil pan gaskets on 1950 98
  196. Any possible headers that fit?
  197. Edelbrock 1407 on an Olds performer 455 intake
  198. buttoning up new build, PCV and crankcase vent question
  199. Check the simple stuff
  200. Decode 455 Motor
  201. 425 cam upgrade
  202. 400BB down pipe / exhaust manifold leak
  203. Rochester 4 barrel secondary not opening
  204. Oil Pan question.
  205. 455 repair/rebuild? Help please!
  206. Speed master oldsmobile heads
  207. DSS vs DMR vs Mondello forged 425 pistons
  208. 1969 442 400ci Carb help
  209. 455 build has come to a stop, help needed.
  210. installing new lunati valve springs oldsmobile c heads
  211. Recommendations for dwell meter
  212. Engine shaking at idle
  213. composite distributor gear
  214. Help me with a budget Piston
  215. Power estimate?
  216. 1972 oldsmobile cutlass 455 auto odd carb issue
  217. 394 valve train oiling
  218. 455 OEM Heads/Intake or Aftermarket
  219. Olds engine builders southeast
  220. Trying to fire new 455 build | Backfired so loud | wont fire up
  221. 455 Newbie Assistance
  222. Cooling issue
  223. OAI with EFI: how should flapper work?
  224. Another HP & Torque Number Estimate?
  225. DOES ANYONE HAVE ACTUAL DYNO A/B RESULTS WITH PERFORMER 455 vs PERFORMER RPM 455?
  226. 70-72' 455 engine paint UPDATED
  227. Gasket match porting?
  228. 72 Alt brackets on new 455 | Alignment issue
  229. 425 swap questions
  230. Oil ports
  231. Head gaskets leaking oil???
  232. 1967 442 engine/head work
  233. Oil on Intake Manifold
  234. Will these fit (AC Delco part #'s 9433773 & 9433753)
  235. Olds 455 in GMC Motorhome
  236. 1963 Dynamic Flexplate help
  237. Hyd roller cam with 5/16 rocker arm studs
  238. Highest Compression Ratio on 455
  239. 455 blocks
  240. Setting timing - Innova 3568
  241. 455 number decoding
  242. Exhaust questions
  243. Looking for a Machine Shop North Carolina
  244. Olds 455 re repair
  245. “c” alternator bracket vs Aluminum head problem?
  246. Olds 496 w/ serpentine convertion 582hp/647 trq
  247. 455 with TRW pistons
  248. heads
  249. lack of oil at top end
  250. Accelerator pedal that periodically "sticks"
