Help with 750 Quickfuel slayer carb.
Old Aug 5, 2021 | 07:42 AM
STLCRZY's Avatar
I have hard time with a 750 QFuel slayer (vac. sec) on freshly rebuilt mild BB.
Engine has a mild cam 218/218 cam and good manifold vacuum (15in/hg) and runs great with a 600 EDE carb
It runs terrible rich and shakes (plugs black) ...cant drive it out of the garage. I dissemble the carb two times to find debris or cracks but everythink sems okay.
All jets are like it came from factory , power valve is stock 6,5
Float level is in the middle of the glases,
Hope anybody can HELP
Old Aug 5, 2021 | 11:12 AM
I set the float to the bottom of the site glass. Have you made sure there is no fuel dripping down the throat? Idle a/f mixture screws set correctly?
Old Aug 5, 2021 | 12:32 PM
cutlassefi's Avatar
Did you crack open the rear throttle blades approx as much as the fronts? There’s a screw underneath for that.
Old Aug 5, 2021 | 08:01 PM
tonka's Avatar
I have the same carb and I'm chasing a similar problem with a bad shake at idle. Seems to run great at higher rpms. I have not yet cracked open the secondaries as Mark has suggested, but I plan to try that this weekend. If you solve your issue, please post your final resolution.
Old Aug 6, 2021 | 01:06 AM
STLCRZY's Avatar
I will try to set it to the the bottom of the glass....
​​ Do you mean i have to check if fuel dripping down the throat with engine off ?
a/f mixture screws 1 1/2 out
Old Aug 6, 2021 | 06:37 AM
Is there fuel dripping with it off, idle, and about 1500 rpm.
Set the A/F mixture with a vacuum gauge for the highest vacuum you can get with the same amount of turns both sides.. Make sure the needle is steady.
Neil lee
Jun 19, 2021 04:40 AM
mattking
Nov 13, 2015 11:59 AM
cwb442
Jun 14, 2015 09:49 PM
65Delta88
Sep 20, 2010 02:42 PM
jensenracing77
Mar 13, 2010 08:52 AM
