Another 455 build qusetion
Old Aug 6, 2021 | 09:19 PM
tkcutlass's Avatar
I just got a quote from E & G for a "Standard build with an RV cam".
Obviously, RV is meaningless without the specs.
They mentioned ARP bolts.
What specifics should I be looking for?
I am not looking to build a monster but if there are some parts that have a big bang for the buck, I don't want to be penny wise and pound foolish.
This is going in a 70 cutlass convertible. with 355 Limited Slip
Tim
Old Aug 7, 2021 | 06:21 AM
VORTECPRO's Avatar
Make dam sure you do your home work on this shop, you might be better off going to a proven Oldsmobile expert. Milan, BTR, Rocket, Andy
Old Aug 7, 2021 | 06:28 AM
cutlassefi's Avatar
Even just a base performance build should always include the following;
ARP main bolts at least
Eagle or Scat rods
An N crank
Proper machine work should consist of align hone, checking the deck, bore, hone with tq plate, crank grind for proper clearances and balance entire rotating assembly
There are a few decent pistons out there as well that won’t break the bank, ie Wiseco, SRP, Icon. That should get you headed in the right direction.
Hope this helps.
edzolz
Jan 10, 2015 08:14 AM
rootney
Jul 27, 2014 04:24 PM
Stevec
Feb 6, 2014 02:18 PM
coppercutlass
Dec 5, 2012 06:03 PM
W70442
Jan 24, 2011 05:37 AM
