Factory throttle cable and bracket question 🤔
Old Jun 1, 2021 | 08:10 PM
72455's Avatar
1972 U code Supreme
1972 U code Supreme with a 770 Holley Street Avenger and Edelbrock Performer intake. Will a factory throttle cable and bracket work?
Old Jun 2, 2021 | 04:39 AM
Nope. The Holley bolt pattern is wider than the Qjet. The stock bracket won't bolt up. I've cut and welded the stock bracket to widen it in the past.
Old Jun 2, 2021 | 05:23 AM
72455's Avatar
1972 U code Supreme
Thanks Joe..and what about the factory cable?
Old Jun 2, 2021 | 05:24 AM
I've made the cable work after modifying the bracket.
Old Jun 2, 2021 | 06:16 AM
72455's Avatar
1972 U code Supreme
Will I need to adjust the cable, and can you post a pic of your setup pls?
Old Jun 2, 2021 | 06:22 AM
Will I need to adjust the cable?
There is no adjustment, other than modifying the bracket to move the fixed part of the cable closer to or further from the carb. That's why there are aftermarket brackets that have this adjustment capability.
Keep in mind that I did this in the early 1980s, so I can't say I remember everything about it. That Holley is why I use Qjets today. Holley is a W.O.T. carb. Great at the track, but lacking in part-throttle driveability. There's always a flat spot. You can easily tune the RPM where the flat spot occurs, you just can't ever get rid of it.
Qjets are arguably the most advanced 4bbl ever made. Triple boosters in the primaries for good atomization, Adjustable Part Throttle on the later carbs, and a lot of adjustability. The fact that one basic carb design was able to be used on engines from 231 to 500 cu in says something about the design and flexibility. This complexity is why people without the skill or patience to adjust them properly crap on them. To each his own.
Old Jun 2, 2021 | 07:14 AM
72455's Avatar
1972 U code Supreme
Thanks Joe..is there any difference between the cable for a Supreme vs a 442?
Old Jun 2, 2021 | 07:15 AM
The only difference is 2bbl vs 4bbl.
azehr
May 20, 2021 06:59 PM
defiant1
Feb 4, 2020 08:53 PM
Fummins
May 28, 2013 06:19 AM
allyolds68
May 3, 2013 01:03 PM
1970442
Mar 21, 2012 11:04 AM
