Lokar throttle cable.
Old Mar 26, 2013 | 12:25 PM
Fummins's Avatar
Hi Guys, needing a replacement throttle cable about now....wondering if anyone has used a Lokar on their car, and if you did which model #? Mine is a 1969 Cutlass with Edelbrock 4 barrel carb. Thanks.
Old May 19, 2013 | 08:31 AM
Daycab's Avatar
Lokar sells universal cables and Summit sells them as packages with the cable bracket included.
I have this project also in the next few weeks as my throttle cable is shot.
Old May 19, 2013 | 08:52 AM
Originally Posted by Daycab
Lokar sells universal cables...
"Universal" as in one-size-fits-none unless you have a Chevy? All the Olds vendors sell the correct cable.
Old May 19, 2013 | 12:20 PM
I got an aftermarket Lokar throttle cable when I installed the Summit carburetor on my 455. It works ok. The bracket doesn't fit snugly on the side of the carburetor. When I let off the throttle the idle steps up sometimes because the bracket gets loose and slips forward. What I need is a bracket that uses two carburetor bolts instead of one. Definitely get the right bracket and cable the first time.
Old May 28, 2013 | 04:45 AM
s i 442's Avatar
Oldsmobile enthusiast
Are you saying they sell the right Lokar cable or the factory cable?
My factory cable used on an aftermarket carb is bent like an "S" because its too long.
Old May 28, 2013 | 06:19 AM
ah64pilot's Avatar
Get the lokar and a Summit (trick flow) bracket...ultimate adjustability and reliability. And they look really nice! I'll post pics when I'm on the computer.
I believe I got the 36" cable IIRC.
defiant1
Feb 4, 2020 08:53 PM
TripDeuces
Jun 11, 2011 10:05 AM
RAMBOW
Jul 2, 2010 07:34 PM
rayvera
Ninety-Eight
Feb 16, 2007 12:33 PM
rayvera
Feb 4, 2007 07:36 AM
