1972 oldsmobile cutlass 455 auto odd carb issue
Old Jan 25, 2021 | 04:11 PM
Old442Head's Avatar
1972 olds 442, E455, T400
Just installed a newly refurbished rochester quadrajet, ran great for a week after tuning it in. Yesterday I stopped to fix the idle screw since I t was running a little high. Noticed that when I went to put the base plate of the air filter back on it would start running rough, and misfire a little. It even happens when it's 2 inches away so it's not air being blocked. I ran a ground from the negative batt to the intake with no luck. Only other thing I can think of is it's a vacuum leak at the base plate since it seems to be the front two bolts for the carb that are effecting it. Here is a post to a YouTube link. Also seems to only happen after it's warmed up, another issue I had was my alternator starter a very faint whine and my battery light will be on only when cold. If unplugged the whine will go away so I'm pretty sure my brand new alternator is toast. Only happens when cold as well? Please share if anyone has had this very odd issue. https://youtu.be/TU8HBLZ_mGU
Old Jan 26, 2021 | 03:00 AM
shiftbyear's Avatar
Loose that air cleaner base, Read this recent post from V8 Buick website. https://www.v8buick.com/index.php?th...t-away.363876/
Old Jan 26, 2021 | 06:01 AM
Was it your alternator or starter that was whining? You can test the alternator with the engine running by measuring DC voltage of the battery. It should be charging at about 13.8 volts. Most auto parts stores will also test an alternator or starter either on the car or on the bench if you remove them.
Old Jan 26, 2021 | 08:55 AM
Old442Head's Avatar
Wow, I've hated this base since the beginning. My trans is out on my 69 c10 so Ive just been using it for now. Thanks 👍.
Old Jan 26, 2021 | 09:00 AM
Old442Head's Avatar
It is the alternator whining but it is still charging little over 14 volts. Whining only occurs cold and will go away if you unplug the connecter. I've spent a full day going over all wires and ground and everything is tip top. My next step is installing a 1 inch insulator riser since I have clearance issues any way, plus I think I have a bad or wrong base gasket since I had to shave off some material to clear the 2ndy throttle blades from hanging up.
Old Jan 28, 2021 | 12:01 AM
Old442Head's Avatar
So nobody has ever seen this happen before I take it? Video on youtube shows what is happening because I can't post on here. It's not just with air filter base it's with anything. I can even put the edge of it on one of the carb bolts and itll start running rough.
Old Jan 28, 2021 | 04:56 AM
(2) The alternator itself is incorrectly wired in your electrical circuitry. I have a '71 CS not a '74, I suspect your alternator contains an internal VR. Make certain you have your alternator wired correctly into your circuitry - double-check any suspect wiring. Make absolutely certain your alternator is designed for your application - not horrendously overrated, and absolutely installed into the circuitry correctly;
(3) Your distributor. You have an HEI installed or contact points? Make absolutely certain it's installed correctly;
(3) Your IGN coil. How is it mounted, where is it mounted, are any wires not wired correctly, is the IGN coil the correct coil for your application?;
(4) Your IGN coil wire. Is it loose, brand new, old, or whatever?;
(5) Make absolutely certain every single power (positive) wire is completely insulated.
^^^THIS^^^
Good description BTW. What your describing is an intermittent short or open in electronics terms.
(6) Examine, remove any extraneous component wiring which is not germane (a common) component to the electrical system...
The god damn Germans got nothin' to do with it!
Old Jan 28, 2021 | 06:42 AM
Old442Head's Avatar
[QUOTE=Vintage Chief;1313829]Here is my take. I've watched your video numerous times. The first time you place the base plate of the air cleaner over the carburetor the vehicle begins to run rough WITHOUT touching any metal. Am I correct with regards to what I am witnessing in this video? You haven't even touched the base plate to metal, but simply placing the carburetor base plate over (in fact, perhaps near) the carburetor the engine begins to idle roughly. Is this correct? You stated it happens when it's 2" away.
Yes or No
Yes, thats why i had no choice but to post on a forum for the first time. I just don't get it. Was hoping someone out there had seen this before.
Old Jan 28, 2021 | 06:53 AM
Old442Head's Avatar
Yes or No
This is certainly a very peculiar phenomena , but not completely without an answer. Determining the answer requires some basic understanding of electricity and more importantly "electromagnetic induction". I'll bet you have a basic understanding of where this is heading, but I have never seen what you're describing on any automobile - which does not mean it isn't possible. I'll leave the whining alternator out of the equation for a minute, but I have my suspicions the "direct" cause is most likely not the alternator, but the alternator might be a contributing factor.
In basic terms, it appears to me you are inducing an electromagnetic potential between two opposing electrical charges, what can best described as an interrupted electrical flow or "eddy". These eddies would/should normally only occur in an AC circuit, where the current flow in both directions - moving in one direction the majority of time, but reversing in the opposite direction during specific intervals; albeit, alternating current. A DC current would not normally be suspect of creating an interrupted electrical "eddy" since the direction of flow is in one direction only.
All electrical devices produce (at the very basic level) an alternating current when you convert mechanical energy to electrical energy simply through the creation of differences in electrical potential. Hang in there, you'll get where this is going. An alternator creates electricity and is designed to produce a large gradient of potential energy (and, so does your IGN coil). That energy (AC from the alternator) is then converted to usable energy on the vehicle in terms of DC. Diodes etc. will trap the backwards AC current and allow the current to run in one direction ONLY. One reason the creation of an eddy will most often never occur within a DC circuit.
Imagine you have a toy train, erector set, a small piece of electrical equipment (a tiny little AC motor) which creates a tiny amount of electrical energy to move the train or whatever. Now, take a magnet and place a magnet next to the tiny little electric motor which is producing this electrical energy. You will find the train slows down, then speeds up as you begin to move the magnet away from, closer to and at varying angles to the tiny little motor. Place two magnets - one on each side of this tiny little motor, etc. etc. This is what creates an interrupted electrical flow or "eddy". You can in many circumstances create this eddy with another large piece of metal held close to this tiny little electric motor. You have disrupted the electrical flow - that "appears" to be what is occurring in your scenario (only on a larger scale). The fact the alternator is whining (you stated only when cold but I'm suspect it happens all the time but you only "hear" it when it's cold, perhaps) demonstrates some suspicion - it should not be whining. Additionally, you stated the whining stops when you unplugged the alternator connector. However, you stated your alternator is producing a little over 14 V, which under any normal circumstance would indicate it's producing sufficient charging to the battery.
So, let's think about this a minute. You "witnessed" this phenomena occurring - you didn't even touch a piece of metal, you only held the base plate w/in 2" of the carburetor and the engine began to run rough. How is this possible? You disrupted the flow of electrical current (the actual electrical potential) somehow and somewhere. "Finding" the issue will be the mystery to solving this puzzle. I have my suspicions and I'll list them for you to validate on your own:
(1) The electric choke (if you have one installed) on the carburetor is incorrectly wired. To remove some doubt about this, you could disconnect the electric choke entirely to see if the issue resolves by repeating the base plate installation with the choke out of the equation;
(5) Make absolutely certain every single power (positive) wire is completely insulated. The disparity in electrical potential (interference to create this eddy) is going to occur on the positive side, not the negative side, IMO;
(6) Examine, remove any extraneous component wiring which is not germane (a common) component to the electrical system - just disconnect them to remove their circuitry from the equation.
Here's where I'm going. "IF" there is a disparity in electrical potential occurring (the creation of an "eddy") it would occur between two points (generally) or near to one point. Between two points i.e. between the IGN coil and the alternator, between the IGN coil wire and the alternator, between some left behind external VR and the wiring to the alternator (again, I have no idea if a '74 had an external VR), you probably did not buy this car new off the show room, I'd suspect any modifications by any previous owners are suspect.
If anyone reading this thread has witnessed this phenomena and knows of a corrective action to resolve your issue, they'd surely be speaking up about it. That's all I have. I'd be pulling my hair out, keep it simple the best you can - eliminate ONE variable at a time.
Now this is what I'm talking about. Can't wait to go out and try some of these. The vehicle has been completely rewired so this is most likely the issue. The alternator is brand new, so I'll be most likely checking every single common component. The only thing I have done is disconnect electric choke. Grounded air cleaner base, intake and carb on separate occasions with now luck of any changes. Also I wanted to point out a key point to this brilliant mind. It only happens after it is at operating temperature, it happens to the point I notice. The battery light on the dash also turns off as well as the whine from alternator after operating temp. It had just snowed 4" and stuck somehow and in my area is hasn't snowed in years so I'm sure I'll be busy in the wrecker today. Thank you so much for your input and I will keep u updated.
Old Jan 28, 2021 | 07:30 AM
I made a point (above) to suggest this is likely on the positive (power) side of the wiring scheme in the AC circuit and not the DC circuit.
Be aware that our cars only have AC Voltage before the rectifier in the alternator or voltage regulator if it doesn't have internal diodes. The points you made in the earlier post are valid though, in that the OP should check all the systems you mentioned for loose wires or improperly terminated ends. ALL of the wires should be crimped properly (if not also soldered) and protected with heat shrink. Frayed wires with an exposed conductor and green corrosion are an absolute NO NO (as are wire nuts used in AC household wiring). This is probably right on track for the OP since he said the car had the wiring harness replaced.
Old Jan 28, 2021 | 07:57 AM
gs72's Avatar
72Cutlass S
Somebody better tell building code enforcement about that. Lol
I found these online the other day and they look like a way better option over wire nuts. For home wiring of course. Not sure they would be a good option for automotive applications.
https://www.wago.com/us/c/wire-splicing-connectors
Old Jan 28, 2021 | 08:25 AM
Good God Almighty, you electrical engineers can keep that stuff. I'll stick with gears and grease.
Old Jan 29, 2021 | 12:01 AM
Schurkey's Avatar
I'd start by making sure that air cleaner base isn't shorting out spark plug wires. Do the plug wires glow in the dark? (Corona effect)
Lyle_STL
Jun 14, 2020 03:55 PM
brown7373
Aug 23, 2015 01:54 PM
antweave
Jul 9, 2013 07:13 AM
VikingBlue
Feb 14, 2011 07:34 PM
BArmand
Jul 16, 2008 06:59 PM
