455 arp main stud kit
Old Jul 29, 2021 | 07:12 PM
jskorz's Avatar
ARP main stud kit came with nuts with integrated washer , also came with separate washers . Do I need to use the separate washers under the nuts even though they have a integrated washer ? ....... Yes I did did have the block line honed ....
THX
Old Jul 30, 2021 | 04:18 AM
rickw30's Avatar
Yes !
Old Jul 30, 2021 | 05:48 AM
cutlassefi's Avatar
THX
Was it align honed with the studs? And if so did they use the washers as well?
Old Jul 30, 2021 | 06:12 AM
jskorz's Avatar
Yes it was line honed with the ARP main studs , and they did use the washers ...
Old Jul 30, 2021 | 06:30 AM
VC455's Avatar
Barely Registered
Here's the explanation behind what you are being told...
The ARP nut is extremely hard and could gall or deform a steel or iron surface under it. Friction under the nut could vary, which would change the clamping force of the nut. That's why cutlassefi asked if the washers were used during line honing.
The ARP washer provides a hard interface between the steel or iron surface and the nut; this avoids galling or deformation and provides a consistent clamping force.
Old Jul 30, 2021 | 07:21 AM
cutlassefi's Avatar
Then as VC said you have your answer.
Old Jul 30, 2021 | 10:31 AM
jskorz's Avatar
Ok that explains it Thanks for your input ....
olds 307 and 403
Feb 1, 2017 04:12 PM
nicks1966
Sep 22, 2013 06:22 PM
Stevec
Aug 4, 2012 06:52 PM
smietana
Jan 15, 2012 08:35 PM
arnoldjr
Sep 7, 2011 05:39 PM
