Dipstick
Old Apr 16, 2021 | 07:27 AM
1976Olds's Avatar
Dipstick
I swapping a 66 425 into my 76 cutlass with the 350 and I can’t find the dipstick tube for the 425. Are the 350 and 425 dipsticks the same or do I need to buy a new one.
Old Apr 16, 2021 | 07:38 AM
Tubes and indicators are matched sets, and there are several different lengths for various engines over the years. You can use what you have and make the stick work: put in 5 quarts of oil, then make a new FULL mark the stick where the oil is.
Old Apr 16, 2021 | 08:32 AM
1976Olds's Avatar
Okay, so 5 quarts is the stock capacity for these engines. Just wanted to make sure this one would work before finding out the hard way.
Old Apr 16, 2021 | 08:35 AM
Supercars sells the correct tube for the 1966-67 400/425 motors, but the reality is, so long as the tube and dipstick match, the year doesn't matter.
Old Apr 16, 2021 | 08:50 AM
1976Olds's Avatar
Alright, thanks for the help
Old Apr 16, 2021 | 08:49 PM
edzolz's Avatar
What Joe said, as long as you have the matching set of tube and stick, the year of application doesn't matter. What matters is the bottom portion below the two dog knots and flange that snugs up to the block. The upper length can be any length as long as it is a matched set.
oldsmobilty
Feb 21, 2017 03:39 PM
Flye
Apr 8, 2013 05:24 PM
66BOAT
Nov 9, 2012 03:40 PM
willj
May 16, 2011 02:54 PM
Jaybird
Jan 29, 2011 01:34 PM
