Plan to replace oil pan gaskets on 1950 98
Plan to do oil pan gasket replacement 1950 98.
Any advice. What will I need to remove to be able to remover the oil pan to install the new gasket. This is what I order but I see in the thread fel-pro is not correct. Should I return if I can?
There's nothing wrong with Fel-Pro gaskets .
I don't know why anyone would say not to use them .
The best idea is to get a 1950 Oldsmobile Shop Manual ;
Original 1950- 1951 Oldsmobile shop manual with Rocket Engine rochester carb. | eBay
That will give all the details on this job and many others .
