Q-JET CFM 78 Delta 403 ?
Old Aug 16, 2021 | 06:25 PM
jskorz's Avatar
I plan on using the original Q-Jet ( after rebuild ) that came on my 403 for the 455 I am building .... does anyone know what the CFM is on that Q-Jet ?
I am under the impression it's 800 CFM , but not sure .
Old Aug 16, 2021 | 07:00 PM
4speed455's Avatar
Yes the 78 quadrajets are 800 CFM with a fully adjustable part throttle. With a proper rebuild and some minor mods it should work well with your 455. I have a similar one for a 77 403 that I plan to build eventually for my 455. I spoke with Cliff over at http://Cliffshighperformance.com He said with my carb number and engine specs he can give me a kit with the correct jets, rods and idle tubes for my application.
Old Aug 16, 2021 | 07:19 PM
At the minimum, it’s capable of 750 cfm. Some of the later Q-Jets on smaller engines are mechanically limited to less than 750.
Some of the later Q-Jets are capable of 800 cfm, thru were used on Buick’s and Cadillac. I don’t recall how to identify those.
If you have a Q-jet on the 403, it can almost certainly be built to work with your application.
Old Aug 17, 2021 | 05:10 AM
Here's the easy way to tell the 750 CFM Qjets from the 800 CFM versions. Look in the primary venturies. The 750 has a ring that goes all the way around the bore. The 800 only has a bump in one location and a larger venturi diameter everywhere else. in the photo, 750 on the left, 800 on the right.
Old Aug 17, 2021 | 05:26 AM
cutlassefi's Avatar
Cliff is good no doubt but it won’t be totally correct. Buy a wideband O2 and tune it right.
Old Aug 18, 2021 | 10:59 AM
jskorz's Avatar
Ok thanks for the input
Old Aug 18, 2021 | 05:25 PM
cfair's Avatar
X2 on the wideband O2 sensor for tuning. You’ll see the AFR mixture or Lambda at all parts of the use cycle - idle, cruise and WOT and can really dial the tuning in.
Chris
KetsMcLets
Nov 13, 2020 12:21 PM
88hurstolds
Feb 22, 2016 02:53 PM
88hurstolds
Jan 2, 2015 10:29 PM
kips70cutty
Oct 5, 2014 04:34 AM
85cutlass6.6
Aug 19, 2011 04:28 AM
