Oil Pump High Pressure Spring
Old Mar 19, 2021 | 08:52 AM
friesjh's Avatar
Hello all,
I am freshening up the 455 in one of my 71 442s and am replacing the oil pump. I bought the Melling M22FHV. My question is about the extra pink spring. The enclosed instructions say it increases the pressure in the pump. Should I use the pink spring? What applications warrant using a HV HP oil pump. The motor is pretty much stock with a nicer cam.
Old Mar 19, 2021 | 09:55 AM
All of them. There is no downside to using the HV pump. The "suck the pan dry" myth is another one that refuses to die.
Old Mar 19, 2021 | 10:01 AM
friesjh's Avatar
I am using the high volume pump. The question is: do I use the pink high pressure spring instead of the green standard pressure spring?
Old Mar 19, 2021 | 10:03 AM
Sorry, didn't read that carefully enough. Higher pressure means more parasitic horsepower loss. For a near-stock engine used for street driving, I wouldn't bump the pressure up.
Old Mar 19, 2021 | 10:05 AM
friesjh's Avatar
Awesome, thanks Joe!
Old Mar 19, 2021 | 11:32 AM
I replaced my stock 350 w/ a Melling & the high volume spring 2+ yrs ago - works like a charm.
Old Mar 19, 2021 | 01:21 PM
OLDSter Ralph's Avatar
The different spring does NOT change the volumn. It changes the pressure.
Old Mar 19, 2021 | 01:50 PM
Ooops. That was probably directed towards me. You're correct. I used the MELLING M22F & w/ the HP spring. Pressure on the brain, volume on the fingers.
I replaced my stock 350 w/ a Melling & the high volume pressure spring 2+ yrs ago - works like a charm.
virtualwsp
Oct 10, 2023 06:08 PM
69Chrgr
Feb 21, 2020 04:50 PM
jmos4
Jun 19, 2016 08:15 PM
Rolds72
Mar 22, 2012 11:08 AM
tim72
Jun 15, 2010 07:45 AM
