pulleys
Old Aug 8, 2021 | 12:00 PM
Olds 66's Avatar
pulleys
Pulley confusion I don''t want to steel your thread but does anyone know if I have to replace all pulleys to change from long water pump to short water pump Any-one know what water pump pulley (2 groove) would fit???
Old Aug 8, 2021 | 12:19 PM
And yet you did...
FYI, that thread was a decade old. Tell you what, here's your own shiny new thread on the the topic.
Yes. The pump, pulleys, and accessory brackets need to be kept together as a matched set. Why don't you just get the correct length water pump to match your existing pulleys, brackets, etc? That's going to be MUCH easier in the long run.
Old Aug 10, 2021 | 07:25 AM
oletrux's Avatar
While we're discussing pulleys........are the pulleys interchangeable between a 403 and 455?
Old Aug 10, 2021 | 07:29 AM
The pulleys go with the water pump and accessory brackets, period. The front of every 1964-1990 Olds block is dimensionally identical. Yes, I'm aware that the BBOs require brackets with a second hole to accommodate the extra inch of deck height.
Old Aug 10, 2021 | 07:35 AM
oletrux's Avatar
Thanks Joe. I'll need to look at the brackets. That was really my question, but I brain-farted pulleys instead.
Bitburger
Dec 21, 2024 06:03 PM
nwcajun
Feb 6, 2023 10:51 PM
tomc5
Jan 23, 2014 08:00 PM
jensenracing77
Sep 19, 2013 02:09 AM
rcrac3r
May 23, 2013 12:08 AM
