Rochester 4 barrel secondary not opening
Old Feb 11, 2021 | 12:28 PM
drjaredshelton's Avatar
1964 Olds 98 394 with the stock 4 barrel. I'm doing a tune up. Noticed that the secondary butterflies don't open at all with the throttle linkage at full open. Primaries are open all the way normal operation. They are freely moving if I stick my fingers in there and open them up, but the linkage doesn't move them at all. I'm in book #1 of the service manuals, but I can't seem to find any info on the operation of the linkage for the secondaries at WOT. Not sure if something is stuck or just gummed up. I'm not versed in 4 barrel carbs all that well yet so any help would be appreciated if you've run into this problem before.
Old Feb 11, 2021 | 12:54 PM
BackInTheGame's Avatar
Others can provide more definitive info. The secondary's only open under acceleration or WOT vacuum load - that is, going down the road. They are not opened by of the linkage.
Old Feb 11, 2021 | 01:00 PM
The thing you are looking at is NOT the secondary throttle blades. It is a auxiliary air valve that is above the throttle blades. The auxiliary air valve only opens in response to the airflow needs of the engine. Moving the linkage will not open it. Revving the engine in park will not generate enough airflow either. I suggest you read the carburetor section of the Chassis Service Manual, which describes this system.
Old Feb 11, 2021 | 01:02 PM
Sorry, but that is not correct. The secondary throttle blades on a 4GC are mechanically operated by the throttle linkage. The auxiliary air valve is only opened by the airflow needs of the engine. The OP cannot even see the secondary throttle blades when looking down into the carb - the auxiliary air valve is above them.
Old Feb 11, 2021 | 01:44 PM
Okay, I'll take a closer look at it next time I'm out there. I'm reading that it needs at least 9" hg to open those. Guess I need to get the vacuum gauge out and see what its pulling......thanks for the explination
Old Feb 11, 2021 | 01:50 PM
I don't know what you are reading, but engine vacuum does NOT open the auxiliary air valve. It is the mass of the air being pulled through the secondaries that opens those valve. A vacuum gauge will tell you nothing. Is there some problem you are trying to diagnose? If not, you are creating a "problem" where none exists. The carb sounds like it is operating as designed.
Old Feb 11, 2021 | 01:55 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If the choke is not open the secondaries will not open. Make sure you are holding the choke open when you try and open the secondaries.
70chevrolet
May 26, 2018 02:43 PM
Macadoo
Jun 19, 2014 08:33 PM
mike623
Sep 30, 2010 08:47 PM
66ninetyeightls
May 18, 2010 02:59 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
