Oil control issue
Old Jul 10, 2021 | 10:51 AM
zekecut70's Avatar
Oil control issue
I have a 455 and at the end of a quarter mile pass the oil psi fluctuates from around 60 psi to about 35-40 psi rapidly , then returns to a steady 60 psi. The engine has a 7 qt. Milodon oil pan with windage tray. I run 7 qts. with filter, no oil restrictors and have the grooved back cam bearings. The oil pump is a Melling HV with purple pressure spring.Not sure if it is a windage issue or am I sucking the pan dry.. How would i know? Anyone ever had this issue?
Old Jul 10, 2021 | 11:13 AM
bccan's Avatar
Are you on the throttle or on the release/coast down when fluctuation occurs?
Old Jul 10, 2021 | 01:18 PM
zekecut70's Avatar
Coast down
Old Jul 10, 2021 | 02:36 PM
cutlassefi's Avatar
Originally Posted by zekecut70
Coast down
That’s one reason why I don’t use that pan anymore. I switched to the Canton which has multiple trap doors in it. Nice piece.
Old Jul 10, 2021 | 04:14 PM
zekecut70's Avatar
So your saying its a windage issue?
Old Jul 12, 2021 | 09:11 AM
Jeff Stout's Avatar
If the pressure returns fast meaning it comes back up when make the turn then I would say windage. If it takes awhile to come up like half down the return road then I would say all the oil is up top due to ne restrictors.
Old Jul 12, 2021 | 02:47 PM
zekecut70's Avatar
It come back to normal rather quick, a few seconds after I let off the throttle.
Pitbul442
Oct 12, 2020 05:12 PM
David DeCan
Jan 15, 2016 07:05 PM
MN71W30
Jun 5, 2010 01:37 PM
442 Guatemala
May 10, 2009 05:04 PM
bennymac
Apr 27, 2007 04:51 AM
