Compression Ratio, Octane & Elevation
Think of higher altitudes like running a restrictor plate motor. The reduced air that reaches the cylinder reduces the cylinder pressure. Reduced cylinder pressure allows for less octane and more timing as previously stated.
A small block Oldsmobile set up with true flat top pistons and an as cast iron head will be around 10.25:1. With a camshaft of around 310 degrees of seat timing on a 104 intake centerline, it’ll run on 93 octane without problems at sea level. If you run the factory W-31 cam with it’s long closing ramps and 113+ intake centerline, 91 octane is possible.
But, if you haven’t measured anything and are seeing if it will run on your current setup, go out and test it. Start out low on the timing and see if it knocks with a load on the motor.
I’ve done a bunch of iron headed 455’s for guys in CA. They were all 10.0:1 and run fine on 91. The tune and combination are key.
orange442
Jul 9, 2015 04:32 PM
