Compression Ratio, Octane & Elevation
Old Apr 29, 2021 | 08:15 AM
pettrix's Avatar
If at 5,000 feet, with 10.5:1 compression, is an engine less prone to detonate on 91 octane than it would at let's say seal level or 1,000 feet?
Old Apr 30, 2021 | 06:44 AM
anoldsman's Avatar
Yes
Old Apr 30, 2021 | 10:22 AM
Tri-Carb's Avatar
For each location density altitude changes every day.
Old Apr 30, 2021 | 12:57 PM
An engine is more prone to detonation at lower altitudes. Higher altitudes can get by with less octane and more timing advance.
Old Apr 30, 2021 | 03:00 PM
anoldsman's Avatar
Think of higher altitudes like running a restrictor plate motor. The reduced air that reaches the cylinder reduces the cylinder pressure. Reduced cylinder pressure allows for less octane and more timing as previously stated.
Old Apr 30, 2021 | 06:15 PM
pettrix's Avatar
Would one be "safe" at 5,000 feet with 10.5:1 compression with iron heads, 91 octane and 30 degrees timing?
Old Apr 30, 2021 | 08:13 PM
anoldsman's Avatar
Was the compression ratio from measured data or from published head and piston specs? What is the seat timing of your camshaft? What is the lobe separation and advance? Did you degree the cam in? If so, what is the actual advance or retard?
A small block Oldsmobile set up with true flat top pistons and an as cast iron head will be around 10.25:1. With a camshaft of around 310 degrees of seat timing on a 104 intake centerline, it’ll run on 93 octane without problems at sea level. If you run the factory W-31 cam with it’s long closing ramps and 113+ intake centerline, 91 octane is possible.
But, if you haven’t measured anything and are seeing if it will run on your current setup, go out and test it. Start out low on the timing and see if it knocks with a load on the motor.
Old Apr 30, 2021 | 09:01 PM
VORTECPRO's Avatar
YES, if the engine is solid.
Old May 1, 2021 | 06:18 AM
cutlassefi's Avatar
That should be no problem.
I’ve done a bunch of iron headed 455’s for guys in CA. They were all 10.0:1 and run fine on 91. The tune and combination are key.
Propaneking
Mar 24, 2017 08:46 PM
orange442
Jul 9, 2015 04:32 PM
rcrac3r
May 7, 2013 12:10 PM
rcrac3r
Sep 19, 2012 11:22 AM
easytobedead
May 12, 2009 03:27 PM
