Question about roller rockers
I have just had my heads refreshed and I have some studs and roller rockers. To use these would I need to buy new push rods valve guides etc or could it be used stock they are 1.6 ratio thanks.
You don't have to change the guides to use roller rockers that are the same as stock ratio. Guides should have been checked when they did your heads.
A good screw-in stud, correct length pushrods, guide plates, and poly locks are all you need to use the correct rocker.
