Engine accessory brackets pics/drawings 1970 455
Does anyone have any multiple angle pics or CSM drawings of the way the bracketry should look on a BBO? I am starting with this:
This is getting pulled and a 455 is being put in its place. I just want to go through the parts and make sure I have everything and how it goes together.
Thanks all,
Thanks all,
We have an Oldsmobile parts catalog for a free download here :
https://classicoldsmobile.com/forums...atalog-129157/
It contains hundreds of illustrations of all parts of a car .
If you are trying to use brackets from a 307 I believe they will not work as they were never designed to work on a BBO because they had been out of production and didn't need to be.
I'm not 100% sure if this is the case, but if it is then you will only need an alternator bracket (assuming no A/C) as the power steering pump is bolted to the lower part of the block and that is the same on a SBO and BBO.
I will be more clear and detailed here to alleviate any uncertainty.
The car: 1970 Cutlass S with a 350 and all stock brackets from 1970.
The engine being swapped in: 1971 455 with G heads with no bracketry (my modified 307 bracketry currently on the 455 will stay with the Silver car).
What I want to do. Use the 1970 350 bracketry (if possible) to put the 1970 accessories on the 455 including A/C. Any modifications necessary, I will do, hence, the need for some pics or drawings...
Thanks 69HO43! I will look through my pile of parts to see what I have and if anything is missing. I can mock it up on the broken 455 on a stand and transfer it all when I am ready for the swap.
Looks like I may have everything needed.
However, doesn't quite look the same as the '69. Hard to tell from the CSM page pics.
I believe the only real difference is whether you have the exhaust manifold to PS bracket support bar and the support bar for the A/C. Which you definitely have the A/C bar. It's not about fitting the SBO or BBO brackets, because they're virtually the same brackets. Just use the BBO holes on the brackets. And, as you point out, the 69 brackets may use different pieces here and there vs. the 1970 versions, but I'm still thinking the brackets can be used for either big or small V8 if you stay within the same year brackets/pulleys.
Checking with the parts book information 68-71 V8 is covered by many of these parts. I didn't check the A/C brackets though. Assuming you got all the parts for the PS pump bracketry, it looks like you're missing the A/C compressor rear support bracket 387582 (last drawing, bottom right). Parts book says fits 65-75 V8 except very few exceptions. The alternator front upper bracket appears to be there, and the rear alternator bracket is in your picture. The front adjustable A/C bracket is same for 64-71 V8 in A-body. The front bracket that bolts to the head fits 68-72 V8.
So it seems that 1970 doesn't own its own bracketry according to the parts books.
Yep, you're right, it looks like I am missing 387582. It also looks like I am missing 401243 shield. I'm not sure what the lower right bracket is in my picture as it doesn't seem to match anything in the above drawings.
And I see that since the A/C side is setup for small or big block, I am good there. The alternator looks like it only mounts to cylinder head locations so no worries there. The power steering looks as though it only mounts to the block so again, no issues there.
Now I just need the missing pieces...
That shield is used only on Toro, but you could use it wherever you wish.
Well, it looks like I have the missing bracket. I didn't think to look at the back of the old compressor. Yep, there it is.
Now, to mock it all up on the 455 I have on a stand...
Yes, thanks a bunch for your help so far! I'm sure I will have many more questions. I am hugely familiar with the G-bodies, but I haven't owned a classic A-body since 1994. And that was a '74 H/O. And that was also before I knew anything about Olds. First G-body in 1996 and that's all I have had since. Til now...
Did you ever get that H/O kit side panel re-attached?
Haha, that '83 H/O was pretty beat. However, mechanically it was great.
I have not reattached the panel, however, I did acquire everything to do the job. It is all laid out in the garage waiting for me to sit down and do it.
Keep in mind that there are two spacers that are needed to get things aligned correctly. One goes on the water pump stud where the power steering bracket mounts and the other is between the bracket and the side of the block. They are shown in the upper left diagram in the first image posted. Since your PS pump is still attached to the engine, they are likely in place.
Good call Kenneth, I will go through the piles of hardware that came with the car to see if they are in there. Hopefully, they are. If not, I could make some if I could get dimensions...
You can also buy just the spacers or the entire pump mounting kit.
https://www.opgi.com/chassis-suspens...c-c241506.html
And usually having to piece together the set from various junker cars if yours were missing. Time is money. Convenient one-stop shopping wins the day when you get those basket case cars.
Yeah, but this also again demonstrates that it is less expensive in the long run to buy as complete a car as possible. The "cheap" basket case cars I've owned have been among the most expensive in the end.
Couldn't agree more. I've bought my share of "pricey" baskets. In this particular case, I'd have bought this car, too on how clean the car was otherwise, and if I had another engine to go in it, a few brackets would be worth the hunt. Generally, unless there's some sentimental value, or you have other plans, or it's a 68 H/O project car you can get for $1,500, try to skip the basket case cars. At least do the math first to see if it's worth it.
Haha! I know what y'all mean. No more "basket case" cars for me anymore.I have the benefit of knowing this car since 1994.AND, my buddy who had it at the time, had it in his family since 1972. It's a damn solid car that I got for a pretty good deal with all of the Olds specific hard to find parts still with it. I was wrong about the wheels. They are 14x7 SS1 wheels. I will probably get these for it:
Planning on going with these from US Mags in something like 18x9. The 14" SS1s will go up for sale at some point soon...
#31
Guys I'm currently doing the exact same swap. 70 Cutlass S. Pulling the 350 and installing a 455. I'm so glad I found this post. I removed all the brackets from the front of the 350 engine. When I was done I found a spacer on the floor and had no idea where it came from. I think I know now.
I also wish to keep the AC. I'm using an Edelbrock intake and I'm finding the bracket that bridges over the right side valve cover doesn't exactly fit anymore. I also remember it not fitting well when I installed an Edelbrock intake onto the 350 a few years ago. I think I'll be able to elongate the holes enough but it's off enough to wonder if it's not the right bracket. Researching this question is what led me here. As far as I can find everyone says it's the right bracket. Anyone else have this problem?
#32
It's the right bracket....the problem is the aftermarket intake. I've seen that on virtually any Ebrock intake w/the factory AC brackets being used. You'll have to mock it up to see just how far off it is. I remember one where I THINK the guy had to have some material added to the bolt hole boss of the bracket up top.
#33
I recall a discussion about that top bracket bolt not being essential for supporting a load, so a smaller diameter bolt with a washer was used by either drilling/threading a new hole or filling in the existing one and drilling/threading a new one. I haven't done it, but apparently it has worked for many.
#34
