394 Water Pump bolt question
Old May 26, 2020 | 01:53 PM
adrianirish's Avatar
I bought a rebuilt water pump and the square bolt on the side doesn't screw in very far, it feels like the threading is binding after I screw it in a tiny bit... What is this bolt for? And should it be easy to screw in our is it normal for it to be tight?
Thanks!
Old May 26, 2020 | 05:17 PM
Ozzie's Avatar
A photo might help.
Old May 26, 2020 | 06:57 PM
Originally Posted by Ozzie
A photo might help.
Just uploaded one...
Old May 26, 2020 | 07:10 PM
OLDSter Ralph's Avatar
Looks like a pipe plug, not a bolt.
Old May 26, 2020 | 07:15 PM
I don't know the name... Is this something that has to be adjusted to certain specifications?
Old May 26, 2020 | 08:36 PM
It is a pipe plug. Normally that port is for a pipe fitting for a heater or bypass hose. The plug is for applications that don't use that port. The threads are tapered pipe threads, They bind so the plug seals. You'll want to use teflon sealer on those threads.
Alvie L
Oct 10, 2016 02:27 PM
amphicar770
Jul 29, 2015 12:04 PM
sixtyfour
Mar 26, 2014 06:00 AM
jerseyjoe
Sep 28, 2012 10:22 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
