425 fuel problem ??
Old Jun 28, 2020 | 01:56 AM
GCH's Avatar
GCH
425 fuel problem ??
Hi when i drive my 98 -65 for a while and the engine gets warm and stop the engine for about
30 minutes and should drive again the engine will stop when i put in R or D. This gets better if the car runs
on idle for a while before shifting gear..Have not this problems with my 88 -65 or GMC truck ( new fuel pumps in both )
This does not happen when engine is cold or a quick engine stop and driving again.
Have a wix fuel filter just above fuelpump.
Old Jun 28, 2020 | 07:30 AM
Why do you think it's fuel as opposed to ignition? Points or an electronic conversion?
Old Jun 28, 2020 | 09:14 AM
GCH's Avatar
GCH
Hi it,s points and dwell ok. If i came home from work ( 15 miles ) and park
the car for a while and later should drive in to my garage the engine will die
when i get a little throttle to get in to the garage so i must wait a little.Sometimes
the engine dies when putting in R or D.
So i suspected an fuel issue , but this have never happend when i coldstart
the engine only after i parked when engine hot.
Old Jun 28, 2020 | 09:25 AM
If it's percolation, you should be able to see the vapors inside the carb. It's also very possible to be a heat-related coil issue.
Old Jun 28, 2020 | 09:49 AM
GCH's Avatar
GCH
Thanks should check this up . It has been very hot here last years about 90F in the shadow
and summer -18 was very hot.
Have tried to move the fuelfilter to above the fuelpump earlier and have fuelhose to the carb
shortest way.
Old Jul 4, 2020 | 11:26 PM
GCH's Avatar
GCH
Was thinking to buy a spacer plate 1/2 inch under the carburator but canīt
find one here in Sweden , any tip where to buy in US ?
Rochester 4bbl , buy parts from Rockauto but they dont have this.
Old Jul 13, 2020 | 09:46 AM
GCH's Avatar
GCH
Hi i just ordered a phenolic spacer and gaskets / studs from this Speed Shop :
https://www.dashman.net/product.html?id=212
If somebode else needs one
Jonmueller1
Jun 14, 2020 03:41 PM
jimmies442
Aug 17, 2013 03:20 PM
Skyko
Jun 2, 2012 09:03 PM
skubydobdo
Ninety-Eight
Aug 13, 2008 10:43 PM
dadweiss
Mar 11, 2008 11:23 AM
