Need converter advice
Old Apr 3, 2020 | 09:55 AM
redbaron442455's Avatar
I need some advice in choosing a stall converter for my 2004r conversion, I have a level 2 2004r trans from bowtie over drives as well as a 2600 10" stall from them, I'm thinking that may be too big for what I want it for, I found a deal on a new tci 242600 12" stall that claims to be 400-500 rpms above stock.
I am trying to make my 72 olds cutlass as steetable as possible, I currently have a th400 with a 2800 stall, 3.73 gears, 26.5" tires, 455 .030 over l2323 pistons, ported C heads, about 9-1 compression, clay smith solid flat tappet cam, 520/520 lift, 240/240 @ .050, 292/292 adv, .020 lash, 108 sep installed at 106, air gap dual plane intake, holley sniper, has about 11.5 inches of vacuum at idle 60kpa on screen, tuned to run on 87 octane e10 gas.
would It be wise to go with that +400-500 from stock stall or should I stick with my 2600 stall?
Old Apr 3, 2020 | 03:00 PM
cutlassefi's Avatar
Stick with the 2600 converter, you have the wrong cam in there anyway imo so staying in the mid 2000’s would do you well.
Old Apr 3, 2020 | 04:02 PM
I currently have a 2800 stall on my th400 and I feel it's way too much, the thing is pretty much un drivable around town with the sniper and synced linkage it came with, I currently have the adjustable progressive linkage and extension and it's much better, but can't seem to get it to run as good as the synced, and Holley tech support says don't run anything besides the synced linkage.
I know the cam is too big for the compression but I'm definitely satisfied driving it around town, (runs on 87 e10, stays cool, runs and idles smooth at 15/1, cruises 16/1 with no pinging, just seems to be short on power above 5k 13/1)
wouldn't the 2600 be similar to my 2800 with the higher first gear in the 2004r?
Old Apr 3, 2020 | 05:17 PM
Grand Nationals and the 442 came factory with a 2800 converter. A good quality converter won’t feel mushy at part throttle. The 10 inch Coan converter in my car flashes to 4200, and drives like a stock converter. I would drive the car for a while before swapping to something else. Besides, if you have a lockup converter on the highway it won’t matter.
Old Apr 3, 2020 | 05:39 PM
cutlassefi's Avatar
It should never ping during cruise anyway, no matter what the air/fuel.
Richen the WOT down to 12.5 or so and see what happens.
Old Apr 3, 2020 | 07:56 PM
I've tried 12-13/1 it all seems the same, it ran really well out of the box with the synced 1:1 linkage, leaning the idle out along with 40* adv at idle, 45* at cruise and 35* wot, but I could not take off from a stop light without spinning the tires, so I changed over to the progressive linkage and the throttle lever extension and it is much better at taking off, but I can't seem to get it to fully learn and keep a solid a/f ratio like the synced 1:1.
Do you have this problem with your sniper/455 builds? Any experience with the progressive linkage? I live near LA so pretty much all my driving is stop and go and hills.
Old Apr 3, 2020 | 08:02 PM
the 2004r converter I have is a PDQ 20010 10" 2600-3500, is this a decent converter? I know my th400 converter works really well while cruising.
Old Apr 4, 2020 | 02:38 AM
dragline's Avatar
redbaron, I just purchase a torque converter from EDGE RACING TORQUE CONVERTERS in Simi Valley. They were highly recommended by my tranny rebuilder. The owner Andre educated me on torque converters, 68 Chevelle 500cid BBC/TH400. Can't wait to let 'er rip.
http://www.edgeracingconverters.com/2004r-c-12_13/
Old Apr 4, 2020 | 10:22 AM
wow that's not too far from me, Ill try what i have first (2600) then go from there, i would just really like to go back to the 1:1 linkage on the sniper, i thought lowering the stall would help with the problem, but ill contact them after i try it if i still have the issue,
thanks
71OldscutlassS
May 12, 2020 05:11 PM
coppertopgmc
Mar 1, 2020 08:15 AM
W30post
Jan 6, 2018 05:25 PM
aribera94
Dec 11, 2014 11:46 AM
tim72
Jun 18, 2009 07:52 PM
