nitrided distributor gear
building my 455 this summer, I am putting in a lunati hydraulic roller , I do not want to use a bronze distributor gear, anyone know who makes a nitrided one? other than dick miller( bit pricy if you ask me) any info would be appreciated
Why are you against the bronze gear? I’d rather replace a gear every couple of years instead of taking the chance of tearing up a cam.
To answer your question, I’m pretty sure comp cams offers a nitrided gear.
Dick Miller is the only one I know of and yes they’re pricey. That’s one reason why I’ve changed roller core suppliers. I’m now using the IG cores from Crane. They have an iron gear pressed on so you can use any dist gear you want.
Unfortunately Comp doesn’t make a nitrided gear for Olds .491 shaft dist. And I wouldn’t use a sacrificial gear either if I didn’t have to.
thanks i guess i will get the one from dick miller , I have the cam so just have to roll with it , just don't want to worry about the brass one, this is not a race car i am working with so it has to be reliable
