nitrided distributor gear
Old May 17, 2020 | 09:41 PM
lukestmz's Avatar
building my 455 this summer, I am putting in a lunati hydraulic roller , I do not want to use a bronze distributor gear, anyone know who makes a nitrided one? other than dick miller( bit pricy if you ask me) any info would be appreciated
Old May 18, 2020 | 07:27 PM
Why are you against the bronze gear? I’d rather replace a gear every couple of years instead of taking the chance of tearing up a cam.
To answer your question, I’m pretty sure comp cams offers a nitrided gear.
Old May 18, 2020 | 09:02 PM
cutlassefi's Avatar
Unfortunately Comp doesn’t make a nitrided gear for Olds .491 shaft dist. And I wouldn’t use a sacrificial gear either if I didn’t have to.
Dick Miller is the only one I know of and yes they’re pricey. That’s one reason why I’ve changed roller core suppliers. I’m now using the IG cores from Crane. They have an iron gear pressed on so you can use any dist gear you want.
Old May 18, 2020 | 10:32 PM
lukestmz's Avatar
OK
thanks i guess i will get the one from dick miller , I have the cam so just have to roll with it , just don't want to worry about the brass one, this is not a race car i am working with so it has to be reliable
Old May 19, 2020 | 07:38 AM
wr1970's Avatar
Good to know . Thanks Mark i will not worry about my distributor gear for my hydraulic cam now.
Old May 19, 2020 | 08:40 AM
cutlassefi's Avatar
You'll need a melonized gear as you have the same core as the op. But with a .500 shaft they're readily available from MSD.
big man
Apr 1, 2018 08:40 AM
BillK
Feb 12, 2018 05:36 PM
1970Olds442
Nov 24, 2017 07:15 AM
cdrod
Sep 24, 2015 08:00 PM
lyev
Jun 14, 2015 04:08 PM
