Need power steering pump bracket
Old Apr 1, 2020 | 10:52 AM
Rick 53 Olds 98's Avatar
Working on a 53 Olds 98. I have installed a 455 and need a power steering bracket. Anybody have one for sale?
Old Apr 1, 2020 | 06:38 PM
2blu442's Avatar
Which style are you wanting? The 1964-67 was in the front up above the water pump. The 1968 and later was down lower on the drivers side, close to even with the water pump pulley. Ah, that raises a question. Which pulleys do you have on the 455? You'll need to match those with the power steering pump/pulley. Most pulleys have both a 6 digit number and a two letter code. If you can find those on the water pump and crank pulley that might help us identify what would be the easiest pump/pulley combination to use. John
Old Apr 2, 2020 | 07:25 AM
Thanks for the quick response. I do have a bracket coming. If it doesnt work I will contact you. Thanks again! Rick
jjokrm
Jan 14, 2026 06:46 PM
OLDDOG57
Jan 29, 2017 05:58 AM
1973hurst
May 4, 2015 06:25 AM
foo
Mar 2, 2014 04:54 AM
olds70supreme
Jan 23, 2014 10:22 AM
