‘65 J88 engine question(s)
Old Oct 25, 2020 | 08:50 AM
tlrche67's Avatar
( newbie here )Currently have a 330(just bought, so don’t know if it even runs )
-how to do a full swap of motor and transmission?
- can a center shifter be put in place of the column shifter ?
Old Oct 25, 2020 | 09:30 AM
Any 1964-1990 Olds V8 bolts in. If you plan to use a big block, you will need the specific exhaust manifolds that clear the steering box and linkage. They are reproduced.
Old Oct 25, 2020 | 11:47 AM
tlrche67's Avatar
Center console
What about moving to floor shifter from steering column?
Old Oct 25, 2020 | 01:11 PM
You can do that with a aftermarket floor shifter. You probably would be better off assessing what you have first. Then after figuring out what you need to get running,stopping and driving safely then think about modifications.
Old Oct 25, 2020 | 01:43 PM
The 1965 B-body cars were available with a floor shifter, so that is certainly an option. Unless you plan to convert to bucket seats, you're going to have trouble fitting a floor shifter in there.
brandon reynolds
Oct 2, 2020 09:51 AM
65droptop442
Oct 23, 2012 04:10 PM
Franks425442
Feb 15, 2011 07:10 PM
club442
Aug 31, 2009 05:44 PM
65az
Mar 27, 2009 05:23 PM
